Boost?
Old Oct 4, 2010 | 07:16 PM
Mrterry1's Avatar
Boost?
I have a stock 06 cobalt ss/sc but I boost 13-14 psi, is that normal? Or do you think the old owner did somthing to it?
Old Oct 4, 2010 | 07:33 PM
CobawLT2010's Avatar
Sounds about stock to me... with our altitude around here...
edit: at least thats what I get from reading the treads around here but someone with an ss im sure will post to conferm...
edit: 12psi is stock boost
btw google is your friend...
Old Oct 6, 2010 | 08:57 PM
rukkee's Avatar
Is the supercharger pulley bolted on ? If it's stock there wont be any bolt's ... they are pressed on from the factory. It could be the gauge is off a little or the cat is starting to get plugged up some . What is the rev limiter set at? 6500 is stock 7000 is staged.
Old Oct 7, 2010 | 01:19 AM
Erod's Avatar
Moderator Alumni
Moved
Old Oct 9, 2010 | 10:26 AM
Mrterry1's Avatar
I jus found out my car is a stage 1!lol
Old Oct 9, 2010 | 11:39 AM
06cobalt racer's Avatar
stage 1 doesnt raise boost. stage 2 does
Old Oct 9, 2010 | 11:51 AM
Lifter's Avatar
This.
Stage 1 is just injectors and a tune. Changing your pulley size changes boost.
I'd say it's normal. And don't trust the stock gauge. It's not exactly the most accurate.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
