Boost Capability of M-62
Old Feb 12, 2006 | 08:25 PM
Pully Police's Avatar
Originally Posted by djt81185
No problem dude...I'm so used to people giving me blank stares when I go into detail I normally just simplify it. I'm glad it makes sense I spent forever trying to proofread it. Also sorry if I came off as cocky in any part of it.
Dan
The part that I was overlooking was the fact that the supercharger is a slave to the engine RPM and builds pressure as the RPM's increase regardless of what the engine wants..leading to the massive pumping losses induced on the system - Even with a bypass system installed, you are attemping to minimize the pumping losses by venting pressure, however there is still parastic drag and wasted pumping. It is different with a turbo as you can control the turbo RPM independant of the engine RPM and in effect get the disired flow and pressure ratios that you want no matter what the engine is doing..this is what makes a turbo harder to tune but more of an "elastic" solution if you can spend the time learning and fine tuning the system. I supercharger spins up when the crankshaft tell it to. A turbo does not care about what the engine is doing...it spins up when YOU want it to (provided you have sized the turbo properly for your application).
Isn't forced induction fun!?!
-P
Old Feb 12, 2006 | 10:21 PM
Fast Freddy's Avatar
Nice post pully police!!!!!!!!
Old Feb 14, 2006 | 04:24 PM
Zooomer's Avatar
Supporting Vendor
http://www.zzperformance.com/cobalt_...les1.php?id=55
Old Feb 14, 2006 | 07:05 PM
Be sure to note in your article how the Gen 5 Blowers use a 60 degree helical twist in the rotors to smooth out the pulses of air.
-P
Old Feb 15, 2006 | 08:04 PM
Jmc007's Avatar
Nice article !
Old Feb 15, 2006 | 09:08 PM
FAST06SS's Avatar
Nice article Zooomer, other then the belt slip issues. never have had them. I've been telling local cobalt guys this since i got mine. The M62 is all we need blower wise.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
