Boost Guage
Old May 24, 2006 | 12:04 PM
sheprd's Avatar
Boost Guage
Hi, I took delivery of my new SS/SC yesterday. Is it normal for the boost guage to stay well below zero while there is no boost? Guage jumps wildly all over while driving. Thanks
Old May 24, 2006 | 12:05 PM
cybcow's Avatar
It's fine.
Old May 24, 2006 | 03:50 PM
l Sh1ft l's Avatar
Mine is at like -20 when sitting. That's aite right?
Old May 24, 2006 | 03:52 PM
CTCOBALTSSS's Avatar
You are just fine.
Old May 24, 2006 | 03:54 PM
06black's Avatar
vacum is good while of the throtle and light cruzing.....better for MPG!!!!
Old May 24, 2006 | 05:26 PM
Blown 4-banger's Avatar
yeah if you look at the gauge for the numbers above zero it says psi for mesuring boost, but if you look at the numbers below zero it says "in Hg" which is inches of mercury for mesuring vacuum. You want good milage, don't let the needle get above zero
Old May 24, 2006 | 07:36 PM
l Sh1ft l's Avatar
Ahh that's too tough for me lol. Hence why I am getting 18 mpg. I think the little gauge thing that tells you what your getting doesn't go below 18 haha because I don't think i'm getting that.
Old May 24, 2006 | 07:40 PM
Tomtwtwtw's Avatar
Reset it and take it down the track for a couple runs, then tell us your results.
Old May 24, 2006 | 09:09 PM
2006ArrivalBlueSS's Avatar
-9 psi should be the approximate reading at idle.
Old May 24, 2006 | 09:26 PM
l Sh1ft l's Avatar
weak. It might be when the cars completely off.
Old May 25, 2006 | 07:35 AM
Badmunky's Avatar
The gaugle will read below 18mpg. I reset it at the track and got 8.9 mpg.
I found that if you keep the boost gauge below 4-5psi you will get good fuel mileg and still be able to get out in trafic ok.
Remember the car needs to be broken in properly or you could have clutch problems as well as other things later on.
Later
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
tomj77
Oct 4, 2015 11:39 AM
