Boost only at 4 PSI max. Codes also. Need help please!
Old Aug 24, 2011 | 12:15 AM
dietztho000's Avatar
Exclamation Boost only at 4 PSI max. Codes also. Need help please!
Had the problem ever since my new motor was put in...
Right now the Heat exchanger isnt working but should be tomorrow, could this be causing it?
The heat exchanger is getting little coolant and its also not dexcool, would that have anything to do with it? Or what else should I look into?
I also had 3 codes coming up without the CEL coming on..
P0172 is due to the injectors – it needs to be disable
P0341 is due to some problem with the camshaft position sensor
P0353 is due to “ignition coil3 control circuit”
Not sure what they mean...or how I can fix em.
I just replaced all 4 spark plugs and all 4 ignition coils above the spark plugs....so not sure why the third code is still coming up...
Any help would be AWESOME!
thanks
Old Aug 24, 2011 | 12:34 AM
SlowCobaltSS's Avatar
Ur heat exchanger isnt working. Whats not working about it? The reason its there is to just hold the coolant like a radiator.
Old Aug 24, 2011 | 12:54 AM
Well I was getting the car tuned, but we data logged it first and the log showed the super charger coolant getting over 200 degrees. Which came to the conclusion that the heat exchanger isnt working.
Before I had the new motor put in, I had the Dual Pass coolant mod. But after, the mechanic took that out and put the stock one back in, but he left all the mods and piping for the Dual pass mod...so instead of removing and rerouting all the tubes, I'm going to put the Dual Pass back in tomorrow to get coolant running back to it.
Old Aug 24, 2011 | 01:05 AM
Maybe you heat exchanger pump isnt working?
Old Aug 24, 2011 | 01:10 AM
We listened and compared two Cobalts to mine, and the pump turns on...which I suppose doesnt always mean it works....How could I tell, I'm going to have it apart tomorrow
Old Aug 24, 2011 | 01:13 AM
IDK how to tell if its working. Im thinking about having my hard wired to my fog lights so its running all the time
Old Aug 24, 2011 | 01:14 AM
If you can find away to make sure its working let me know
Old Aug 24, 2011 | 01:20 AM
Will do, think that would cause the boost to be less than 5 PSI? Or you think its something else?
Old Aug 25, 2011 | 02:23 AM
Well Update....
I got the Dual Pass all tubed up and working again.
I also swapped superchargers, manifold intakes, and even cleaned the TB. Still the car get less than 5 PSI....
What other causes could be doing this? Anyone out there know?
Old Aug 25, 2011 | 02:59 AM
Vacuum leak
Old Aug 25, 2011 | 12:22 PM
where are the vacuum lines on the Cobalt?
Old Aug 25, 2011 | 12:27 PM
Coby The Killer's Avatar
check on your bypass valve. It is possible you have the vacuum lines reversed on that.
Old Aug 25, 2011 | 12:34 PM
Thank you Coby for the info, I'm new to this car, were is the bypass valve located?
Old Aug 25, 2011 | 12:40 PM
it is the little black canaster looking thing on airintake side of supercharger. will have 2 vacuum ports coming out of it.
Old Aug 25, 2011 | 12:48 PM
Thats what she looks like, it seems everything is in tack...hopefully they are all in the right place
Old Aug 25, 2011 | 12:51 PM
appears they are correct, hummmmm
Old Aug 25, 2011 | 01:03 PM
I've seen a couple other threads about it....and a lot of people say its the supercharger going out or something about the TB.
Which I've swapped superchargers, and I've cleaned the TB very well....
I'm not sure what else would cause it to only run a max of 4 PSI....all the power is drained from my poor SS...
Old Aug 25, 2011 | 01:04 PM
hey imma send u a pm, with my cell number text me and lets see if we can get if fixed for you.
Old Aug 25, 2011 | 11:48 PM
Problem solved! It was a bad Boost Sensor!
Old Nov 18, 2012 | 06:32 PM
juice3's Avatar
Sorry to resurrect such an old thread, but this is my exact problem with my car at the moment, i see the OP hasn't been on since feb.... Does anyone know of this boost sensor he's talking about? Location or anything? I just swapped supercharger yesterday, swapped boost solenoid, bypass valve... no boost leaks, still boosting 3/4 PSI.
Old Nov 19, 2012 | 12:51 PM
juice3's Avatar
bump for help!
Old Nov 19, 2012 | 01:07 PM
GoofyBalt's Avatar
The only thing that really controls your boost is the bypass valve, if that opens up then you wont be creating any pressure.
Old Nov 23, 2012 | 12:59 AM
juice3's Avatar
Yeah, my boost bypass valve is brand new tho....
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
717ssbalt
Oct 2, 2015 04:01 PM
Sep 27, 2015 08:53 PM
