boost ?'s bypass ?
Old May 25, 2010 | 06:26 PM
edmbaltss's Avatar
boost ?'s bypass ?
so i have been reading different post and am wondering if i have a problem or if it is normal my peak boost is about 110 kpa or 16psi i have a cai mid length header full 3" magnaflow exhaust 60#'s 3" zzp pulley and custom HP tune also on the bypass solinoid it looks like there is the hose from the mani to it then it looks like i have 2 hoses on the other side of it is this right i dont know cause i bought the car new and it loos like one is broke off and it sounds like an air leak there any help would be nice
Old May 25, 2010 | 06:56 PM
Smus's Avatar
Take a picture if you can. Mine has broken off from the bypass valve actuator (the black cylinder with a hose running from the supercharger). If that's the case, you will be running more boost, I run 10 psi at WOT versus 7~8 psi stock, however 16psi is a lot more than stock.
Old May 26, 2010 | 01:07 AM
mrbelvedere's Avatar
12 is stock not 10 and he probably has a pully to make 16 or a cloged cat
Old May 26, 2010 | 10:00 AM
edmbaltss's Avatar
i dont have a cat and i have a 3" pulley i have all my mods in the op
Old May 26, 2010 | 10:44 AM
denlou's Avatar
I make about the same boost on my 2.9 pulley with 2.5" catless exhaust.
Old May 26, 2010 | 11:05 AM
freakta's Avatar
i made around 15 on my 3in
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
