Boosting only 10
Boosting only 10
I have 6,000 miles on an 07 and still boosting ony 10. I was thinking of disconnecting the battery for 15 minutes to maybe reset the computer. Will my radio need to be reset?
Reseting the computer and disconnecting the battery will do nothing, it has nothing to do with the computer or any of that.
There are a lot of things that will effect the amount of boost you are putting out.
It wasn't until about 4 months ago when the car rolled over 12,000km that I saw 85kpa (12.3psi), and even more recently (pre gms2) I managed to run up as high as 95kpa (13.5psi). I see my best boost numbers in WOT in 3rd gear.
Since I went Stage2 this week, I've had it up to 110kpa (15.9psi) and I'm confident it will go up depending on the conditions and how hard I drive it.
Youll only see 12.5 stock at redline.
Alot of people punch it, look at the gauge, and thing WTF 10?!?
basically theres a peak instantaneous boost, and a peak boost.
when you punch it, stock youll see about 10, and as you build to redline in 2nd and especially 3rd+ youll see your peak of 12.5 ish
Stage 2 that instant boost hits 12.5, and builds to 15 etc etc.
hmm ive not read anything about this yet.... ive been searching for a while to find out what stock boost is supposed to be... mine runs about 15 pounds and im almost positive its a stock non staged cobalt
Sl0wbaltSS
Nov 21, 2018 11:11 PM
