Burning Smell After Hard Pulls?
If your on the stock dp the cat could be burning off some build up .... I've seen quite a few LSJ's plug up Cats over the years ....... I had one replace on my 06 SS/SC with 30K miles on it .
I get this smell too after pulls. Full traction. My velt is fine. New clutch. Also made this smell before and after i replaced my cat, clutch, and belt.
I think it smells about the same as clutch/brakes and i smell this after a pull before i hit the brakes so im fairly confident is not that. I dont get any noticeable slip either, my tensioner is new as well. Sooo idk lol. Just stuff getting hot and moving fast i guess
I use to get this a little and now that my cars modded I notice it more I noticed it the most with upgrading injectors to 80# I'm guessing that its excess fuel/carbon burning nothing to worry about check your coolant level though you said your cars stock so no option b kit? make sure your not sucking coolant through you cooler It happened to me the orings wore out an coolant was leaking into my engine and burning up. Didn't really smell like burning plastic more sweet smelling with LOTS of white smoke
#38
If you guys feel u have this issue, you are more than likely running very rich.
I would check the O2 sensor, clean the MAF sensor, check your plugs, check your air filter, and go from there.
You really shouldnt be smelling anything unless you are catless.
roth
09-26-2015 12:16 PM
