CANNOT get belt on!
Old Dec 22, 2010 | 09:03 PM
  #51
rcfreek's Avatar
i took a 13 or 14mm wrech cant remember which one but i took grinder and grind the wrench down little at a time to get it to fit real tight on tensioner and it worked for me???
Old Dec 22, 2010 | 09:15 PM
  #52
CanadianCobalt's Avatar
Originally Posted by Sergio
Take the zzp belt and throw it away!
First of all, the ZZP "Stage 2" belt is not a genuine GM belt - it is slightly under sized and is of extremely poor quality! My belt was had CHUNKS missing out of it after only 5000 miles and it was cracked everywhere.
I replaced it with a real GM Stage 2 belt from CrateEngineDepot and it has been perfect ever since. Went on easily too, because it's the correct length!
Good luck.
No ****? mine did the same thing. I e-mailed them about it today. Explains it.
I asked if it was a brand new belt because it didn't come in any packaging. They said it was indeed new. Makes sense it didnt come in packaging now.
Joel
Old Dec 23, 2010 | 01:12 AM
  #53
srt-10's Avatar
Originally Posted by Sizzle06
Use a pry bar to push down on the tensioner,much easier
thats what i did, used the end of a tire iron to push the tensioner down when i switched to the tvs and then back to the m62 with a 3" pulley.
Old Dec 23, 2010 | 01:53 AM
  #54
ionRL_585's Avatar
Easiest way to do it. I've taken my belt off tons and never had an issue
yeah seriously i got it on tuesday after trying the suggested 15 mm open end wrench, pry bar, and having a fat kid stand on it haha but no really the hammer and the 9/16 works beautifully.
The best part is my gm tech buddy and toyota tech buddy tried many times but failed, then I decided to give it one more shot since the weather FINALLY cleared up [its snowing here in NY] and I used the 9/16 to get the tensioner down and she slipped the belt on. Needless to say its nice to have a lady around even where you least expect one to be handy, **** she sure proved us all wrong even though i did all the "hard" work.
Old Mar 29, 2011 | 02:31 AM
  #55
ionRL_585's Avatar
I saw a video of some guy using a torx 50 bit to get the tensioner to release. The 9/16 technique is starting to round the little notch off and all the other ways are destroying my pulley and belt. Anyone else use the torx bit technique?
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
bobbob160
Sep 15, 2015 11:31 PM
