car wont start after fresh build
went out and checked harness, its plugged in all the way. I had the head rebuilt by a really good engine guy with a million dollar machine shop. Timed the cams and aligned the dot on the crank with the chain at 5 oclock and the cams are lined up with the chain marks. Exhaust and Intake markings.
I have HPT for that.
Last edited by c130aviator; Jan 24, 2013 at 08:58 PM. Reason: Automerged Doublepost
Gonna run the car 500 miles (about 2 weeks) on my current tune. I scaled the Injectors and have had ccss3 give me a basic maf tune in the past. Then I am goint to get on the dyno next month. Running on the WG spring (15lbs) for now. Then I am going to turn the boost up as far as the 20g and e85 will let me.
This site says I may not be able to go over 25 psi with an internal wg. We will prove or disprove that in a few weeks. Mitsubishi 20G
unplugging and replugging the cps means the cam position sensor is out of position. Mr.Belvedere posted a picture, u gotta align it right or the car will have extended cranks no start. good luck with the rest of it, looks like u are almost there.
Thanks, I will look into that, thing is I have it aligned, I told my machinist to mark the cam position sensor and there is a yellow mark making sure its perfect. :scratching head
