car wont start after fresh build
Old Jan 26, 2013 | 02:33 PM
  #51
c130aviator's Avatar
even the crank was off 3 full chain lengths off the white dot... so it was in time still but the entire chain moved off all points 3 chain lengths. anyone ever heard of that?
Old Jan 26, 2013 | 02:35 PM
  #52
Originally Posted by mrbelvedere
you can roll the engine over fast enough by hand to keep the slack out of it not tot mention there is no oil pressure to enough tension I wonder if the sound is the valves smacking the pistons
GDS
i thought our engines were non interference?
Old Jan 26, 2013 | 02:38 PM
  #53
YelCal7's Avatar
GDS
That will SUCK if his Valves smacking the Pistons. Let's hope its not smacking cause if it is then He is SCREWED! My father n I did timing chain on his old car. He forgot to rotate his timing chain first, He just took timing chain without rotate his DAMN JAPS Car. LMAO! I know it's different than build. I really hope that He didn't get his Valves smacking up his Pistons. We will see what happen.....
Old Jan 26, 2013 | 02:41 PM
  #54
BLAZIN07SS's Avatar
I'm too JDM for you
Ecotecs are interference engines
Old Jan 26, 2013 | 02:57 PM
  #55
Tjolley's Avatar
It all depends on how your pistons were made.
Old Jan 26, 2013 | 03:05 PM
  #56
Tjolley's Avatar
My 2.4 lsj will be non interference.
Old Jan 26, 2013 | 03:11 PM
  #57
ok just got off the phone with gm tech here that is also my tuner. He told me that the chain will be off per the gm service manuals and that even after you time them after certain amount of revs it will be off. If the chain is off the same amount on all gears then its still in time. I am still in time. So no interference.
2: I pulled the spark plugs and turned the car over by hand, there is no noise in the valve train at all and the chain although not on the markings are all within 3 links of the cog markings. So its not hitting.
3: 2.2 and 2.4 ecotech is interference, the DESTROKED 2.0 motor is non interference and my pistons are valve relieved.
Old Jan 26, 2013 | 03:15 PM
  #58
YelCal7's Avatar
Ok, That's a GOOD thing.
Old Jan 26, 2013 | 03:26 PM
  #59
video coming, just checked the oil at the plug, no metal no flakes noting that the rods are not binding or shaving metal into my oil. Filter is clean, no metal...
Old Jan 26, 2013 | 03:40 PM
  #60
here is another 2007 making the same noise. All the youtube vids seem to be tensioners...
my video from my findings so far today.
Old Jan 26, 2013 | 03:52 PM
  #61
zrated89's Avatar
ALWAYS ALWAYS DISABLE SPARK AND FUEL, (DONT HAVE TO PULL THE PLUGS) AND PRIME THE ENGINE FOR A GOOD 20 SECONDS. Dam cap locks was on lol
Old Jan 26, 2013 | 03:53 PM
  #62
zrated89's Avatar
did u replace your tensioner? i hope with the newer design? If u dont prime the motor first there is no oil pressure in the tensioner to keep pressure on the guide and just firing her up could jump timing
Old Jan 26, 2013 | 03:56 PM
  #63
Powell Race Parts's Avatar
gotta shake my head; install new engine in car/fill with oil and coolant/ start car/ done.
Old Jan 26, 2013 | 04:05 PM
  #64
mrbelvedere's Avatar
maybe it dose
your gm tech guy is wrong on the 2.1 it is an interference fit engine and the timing marks line back up you just have to rotate the engine over a **** load of times 30 some times try replacing the tensioner
GDSEM
Old Jan 26, 2013 | 04:29 PM
  #65
klutch814's Avatar
yea i thought mine was outta time to lol then i relized. i would try tensionor. i had chain guids snap that sucked
  #66
GDSEM
zrated, i am buying a tensioner today.
powell, please elaborate, I have built many 4x4 suspesnions but being my first engine build I am a complete noob. what else should I have done.
mrb, i cant find my reference but if you guys look hard enough the info is out there on it being non interference. i have read it, I wasnt told it. Tensioner it is based on a thread i just read over at the lnf side of the forum. and based on vids of cars that sound like mine on youtube. zzp says dont replace the chain... I did.
Old Jan 26, 2013 | 04:39 PM
  #67
my guides didnt snap because I never took the car over 900 rpm, my car idles at 900 with 80lb injectors and was too afraid to rev it until i was sure the sound was not something that would damage the car. seems like all signs point to this part
part number 12608580
Ecotec Timing Chain Tensioner 12608580
Is this the revised tensioner?
Old Jan 26, 2013 | 04:54 PM
  #68
well we just tore tennpenn's 2.1 apart and it is an interference fit your information is incorrect
Old Jan 26, 2013 | 05:03 PM
  #69
YelCal7's Avatar
Yep! That's the 1!
Old Jan 26, 2013 | 06:32 PM
  #70
cant argue with that. hopefully its just the chain.
When I get the new tensioner can I run the car with the vc off to see what the noise could be?
Old Jan 26, 2013 | 06:46 PM
  #71
YelCal7's Avatar
HELL NO! You will be squirting Oil ALL OVER PLACE! LMAO!
Old Jan 26, 2013 | 06:48 PM
  #72
no LOL! run the starter with the ignition and fuel pump relay or fuse pulled.
Old Jan 26, 2013 | 06:50 PM
  #73
YelCal7's Avatar
I dunno about that MrB knows the answer. Wait n see what he has to say about that.
Old Jan 26, 2013 | 06:57 PM
  #74
yes. did you not install this?
if you used the old style tensioner, the re-install procedure is long and involved and not plug and play.
Last edited by Powell Race Parts; Jan 26, 2013 at 06:57 PM. Reason: Automerged Doublepost
Old Jan 26, 2013 | 07:00 PM
  #75
replace the chain> good. new updated tensioner, sprockets, guides, fasteners and higher capacity oilers? all in the kit that CED sells for 230 dollars or so. I hope so. If not stop, install all this and you had better check and hope the valves have not crashed into the pistons... sad to say.
PS: ZZP know a lot, and talking to them at length at the CED meet they commented on how good the chain is. But on high mileage SAABs I see the chain giving up. I have seen stretched chains on LNF. So in conclusion, in any engine build I automatically replace the entire front chain drive kit. And tell customers it is a mandatory item. Along with a new TOB for the clutch, new axle seals for the trans, new seal for the distribution block, etc. If the customer does not want, then I either wont do the job or they accept the job with zero warranty.
