Cheapest GMPP?
Cheapest GMPP?
Who sells it at the lowest price I only found 1 place and it seems very expensive\
also is GMPP 2.5 or 2.25' if it's 2.25 thats useless
it's 2.5" stainless steel. i got mine used from another member but the best deal i've seen around is Cobalt / G5 Cat-Back Exhaust System Performance 17802111 - Crate Engine Depot
Really? Thanks for the info. It makes sense that there would be some gain, but from what I've been hearing the gains are in the 4-5 whp range.
Cobalt-Addiction | Performance Parts they got a GMP on there as well but it's only 2 1/4' which makes me weary but if u say others r 2.5 i will purchase soon
GM Performance Chevy Cobalt Catback EXHAUST . Checked from the GM dealer this will fit 2.0L / 2.2L 2door or 4 door , SS , LS , LT .....yes it will fit all the models. This is the exhaust with the part number ending in 1 which GM lists as the 05 - current cobalt & SS cat back exhaust system . Cobalt SS Performance system raises oem sound levels over the 90db level. (slightly less on the Non - SS models) This setup as with all the GM exhaust setups does NOT come with an exhaust tip . All piping is 2 1/4 " od and comes with complete installation instructions and hardware needed. GM instructions are extremely precise and easy to follow. Maintains GM factory warranty.
the gmpp is 2.25" NOT 2.5" dont listen to anybody else. and you make think the 2.25" is useless but the flow is alot better then the stock, i know someone who dynoe'd 10 more hp over their magnaflow system with the gmpp.
I wouldnt say you can expect a solid 12hp from the GMPP catback but 5-8 whp is def possible.
tamadrummer
Sep 23, 2015 02:26 PM
