check engine.
Old Nov 16, 2010 | 04:02 PM
T CUPP's Avatar
check engine.
my check engine light comes on for no reason. i took it to advanced to get it hooked up and they could not find anything wrong with it. it comes on for a day or two then it turns off. could i take it to a chevy dealer and get them to do like a retune or something of that sort?
Old Nov 16, 2010 | 04:05 PM
umrdyldo's Avatar
You need to take it to Autozone or wherever as soon as it comes on. They should be able to read it. Might show up as a recent code as well.
Old Nov 16, 2010 | 04:07 PM
Bl4des's Avatar
if you go to a shop with a better scanner then what autozone uses they will be able to see what it was
Old Nov 16, 2010 | 04:11 PM
killianss's Avatar
You should wait untill the code is there before bringing it to advanced auto. Also fyi the dealer will most likely cost you like 90$ just to look at it so make sure its on before you go there as well.
Old Nov 16, 2010 | 04:13 PM
Hockeyman's Avatar
probably a lean code from your intake, nothing to worry about...just check and make sure you have no leaks.
Old Nov 16, 2010 | 04:14 PM
gwatson650's Avatar
it's probably from crusing on 150, mine used to do the same thing.
Old Nov 16, 2010 | 04:16 PM
T CUPP's Avatar
a code dont pop up it. the check engine light just turns on
150?
killianss's Avatar
Generally when a check engine light turns on your car is throwing a code. I could be wrong though.
Old Nov 16, 2010 | 04:19 PM
T CUPP's Avatar
ohh i got ya now. where is a place that has better scanners than my local autozone
Old Nov 16, 2010 | 04:25 PM
umrdyldo's Avatar
was the light on when you checked at Autozone. I can't imagine it didn't pick up a code when the light was on.
Old Nov 16, 2010 | 04:27 PM
T CUPP's Avatar
i believe it was on when i pulled into advanced but i think it went off when the guy started hooking it up....i could be mistaking though.
Old Nov 16, 2010 | 07:16 PM
Mclovin23's Avatar
could be misfiring if it goes away relatively quickly and comes back randomly
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
