clutch issues
Old Aug 6, 2010 | 04:00 PM
Redefined1's Avatar
clutch issues
just had my motor rebuilt and im having troubles getting it to go into first and reverse. reverse is really bad as it makes a loud thump noise like the clutch is engaging before i release the pedal. i have already bled the system multiple times. hoping someone could help with this issue as it was working before i got my motor built and the tranny pulled.
Old Aug 6, 2010 | 05:04 PM
chris88z24's Avatar
Did you replace the throwout bearing?
Sounds like a leak somewhere.
Old Aug 6, 2010 | 05:57 PM
Frew's Avatar
shifter fork? shifter position? maybe needs adjusted
Old Aug 6, 2010 | 06:26 PM
VERTZX's Avatar
hope that its nothing, try to put it in 1st then reverse, it stops my grind, but idk about a thump. and ur having problems with 1st too. ugh! where did u get it done at?
Old Aug 6, 2010 | 06:56 PM
Redefined1's Avatar
a guy here in springfield that used to work for all out performance but branched out and made his own company.
i missed a sympton. i have to shove it in, to get it into first and reverse. it will go in but its a bitch. this is while im stopped and sitting in my driveway. im afraid to drive it as sometimes it wont let me into a gear at all. especially after WOT pulls, it gets very bad.
Old Aug 6, 2010 | 08:52 PM
chris88z24's Avatar
Was. The. Throwout. Bearing. Replaced?
Old Aug 6, 2010 | 10:39 PM
Redefined1's Avatar
i have no idea, thats why i didnt respond. i would have to talk to the mechanic.
anyways im taking it to a different mechanic tomorrow. we will see his diagnosis and i will post what he says.
Old Aug 7, 2010 | 12:01 AM
chris88z24's Avatar
Take it back to the original place where it was replaced, and find out if the throwout bearing inside the transmission was replaced.
Don't you have a receipt?
If that wasn't changed, that's almost definitely the problem. Unfortunately you'll have to pull the tranny again to swap it out. It helps to replace the metal clutch pipe while you do this as well, because that can leak and cause issues like you are describing.
Do it once, and do it right!
Old Aug 7, 2010 | 12:30 PM
Redefined1's Avatar
is a throwout bearing a piece that has to be replaced everytime you get into the tranny?
Old Aug 9, 2010 | 10:49 PM
Redefined1's Avatar
they are telling me its either the slave or master cylinder(s) but i also noticed that the rod on my clutch pedal is a little bent. i will try fixing that first and see what happens.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
