Compression test, what's yours?
Elevation can have an effect also.
Like blue said u can get different numbers from different tester.
Seems that they r all close to one another is a good sign. Just put some new plugs in it check the oil and shut the hood and drive it.
@925 ft above I don't think its a factor it needs diaged and fixed before more damage occurs
I understand.
The OP isn't in here complaining about oil in the intake or his plugs looking like **** or his car running like crap. He did a compression test and came up with low numbers on every cylinder.
A co-worker has a 04 cavi 2.2 with well over 300k on the engine. Never has done any major work. Besides basic tune ups. He's been running it for a year or more with 125 psi across the board.
That's y i say put some new plugs in it and run it till it dies. If it works don't fix it. Lol
Let be honest here, the car has 150K miles wiht a TVS and Meth, some wear is going to occur, i imagine the car doesnt just crusie at 3K rpms all the time.
IMHO i would just enjoy the car. if you really like it and want to keep it, buy another block and build a motor while you're driving this one.
I just did a compression test on the weekend. Used my buddies Gauge which was an older one and it read 130 across the board. Went home and used my own and it read 200 across the board. Depending on the life and quality of the gauge they can be that far out.
But a leakdown test would tell the exact tale.
