Compression test, what's yours?
Old Sep 4, 2013 | 07:10 PM
19transam81's Avatar
Dd mine today. At 150,000 miles I was at 155 across the board. Is that good, bad or indifferent ?
Old Sep 4, 2013 | 07:21 PM
jp1600's Avatar
Lsj, 210
Old Sep 4, 2013 | 08:16 PM
Looks bad for me lol
Old Sep 4, 2013 | 08:20 PM
mrbelvedere's Avatar
it is bad should be 180 to 210
Old Sep 4, 2013 | 08:22 PM
Tjolley's Avatar
180 is more common on the lsj.
Did u try a wet compression test??
At least the compression is the same across the engine. No reason to touch the engine. Shut the hud and keep driving it. Lol
Old Sep 4, 2013 | 08:32 PM
Yeah I think I'll just drive it till its done. How much time do you guys think it has?
Old Sep 4, 2013 | 10:07 PM
Bluelightning's Avatar
Got Bewst?
You can grab 3 different compression testers and get 3 different readings. As long as they are even across the board, run it IMO.
Old Sep 4, 2013 | 10:10 PM
574's Avatar
574
Run it! If you get numbers like mine, then worry. 74,xxx numbers were 180 180 0 0
Old Sep 4, 2013 | 11:49 PM
over 9000
Old Sep 4, 2013 | 11:51 PM
Tjolley's Avatar
Elevation can have an effect also.
Like blue said u can get different numbers from different tester.
Seems that they r all close to one another is a good sign. Just put some new plugs in it check the oil and shut the hood and drive it.
Old Sep 5, 2013 | 12:26 AM
there is a need to touch the engine if tis the ring set it will soon start blowing the stick out I its valves you stand a chance of them starting to burn
the readings wont be that far off it needs fixed
@925 ft above I don't think its a factor it needs diaged and fixed before more damage occurs
Old Sep 5, 2013 | 08:01 AM
Tjolley's Avatar
I understand.
The OP isn't in here complaining about oil in the intake or his plugs looking like **** or his car running like crap. He did a compression test and came up with low numbers on every cylinder.
A co-worker has a 04 cavi 2.2 with well over 300k on the engine. Never has done any major work. Besides basic tune ups. He's been running it for a year or more with 125 psi across the board.
That's y i say put some new plugs in it and run it till it dies. If it works don't fix it. Lol
Old Sep 5, 2013 | 09:52 AM
the reason needs to be found and fixed
Old Sep 5, 2013 | 10:01 AM
LS6Rally's Avatar
Let be honest here, the car has 150K miles wiht a TVS and Meth, some wear is going to occur, i imagine the car doesnt just crusie at 3K rpms all the time.
IMHO i would just enjoy the car. if you really like it and want to keep it, buy another block and build a motor while you're driving this one.
Old Sep 5, 2013 | 10:08 AM
there are plenty of high mile lsj's out there with in spec cylinder pressure that have had the **** beat out of them
I would do a leak down to locate the problem
Old Sep 5, 2013 | 10:48 AM
Got Bewst?
I just did a compression test on the weekend. Used my buddies Gauge which was an older one and it read 130 across the board. Went home and used my own and it read 200 across the board. Depending on the life and quality of the gauge they can be that far out.
But a leakdown test would tell the exact tale.
Old Sep 5, 2013 | 01:20 PM
Vander Nars's Avatar
Lol i see mrb still trolling
hacadacalopolis
Oct 28, 2015 06:09 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
jmelton327
Sep 26, 2015 10:04 PM
