coolant in my oil
cometic blew out first, put a stock HG. Then cracked a sleeve few days later...
block is going to darton the first of nov, getting sleeved and decked 1285.00 OTD
then im putting the old piston i bought from you and the new set of rings in and new rod and main bearings.
im need to find myself a balance shaft delete probably from lvl 0
looking that way, my deal with zach is falling apart... he told me he had a long block for sale and he would bring me the short block. come to find out its a bare block... silly guy trix are for kids...
he was gonna get 2000 off the kit and free install. equaling a savings of 3k
he didnt know there was a difference between "short block" and "block"
and now that darton has seen pics of my block and the crack, i found out my block is still perfectly good for a sleeve job. then i'll still be turbo and finally have the weak link addressed
thanks for the support along the way!
Last edited by hungryhip-ccp; Oct 6, 2009 at 02:57 PM. Reason: Automerged Doublepost
Cometic's used to be a good name, but they seem to be failing on every car platform lately. I always recommend people to stay as far away from them as possible.
http://www.dartonsleeves.com/Ecotec%20Manual.pdf
Ok here's the deal I did a leak down test and # 4 piston is at 120 compression and the other 3 are 170. So he thinks I might have messed up the head. He doesn't kno if there is any damage under the head. My question is do u think there will b damage on the bottom half of the motor? Where can I buy head studs, head gasket,diamond piston, valve springs, valves, piston rings, connecting rods? If its jus damage to my head he said about $1000 to fix it and if its bottom half about $2000 to fix plus cost of upgraded parts. What u guys think?
importkiller
Sep 30, 2015 07:18 PM
