cx racing h/e installed with pics
Old Apr 20, 2008 | 08:21 PM
idunn's Avatar
Originally Posted by AcesNEights
How wont it do anything useful? its doing the same exact thing as the other way to run it is.
he's saying that its pointless. waste of hose. its like getting into your car, but from the passenger side. ya, you'll still get there, but it would have been easier to get in from the driver side, and you wouldnt waste as much time.
Old Apr 20, 2008 | 08:55 PM
QUAD442's Avatar
guys, ive looked at my cxr for days now trying to figure out how to mount the thing and not hang below the bumper. there is exactly 3"- 3 1/8" from the a/c condenser to the bumper bracket. the cxr is 2 7/8" thick.
Point is that the only way for this to not hang low is to notch the bumper bracket for the nipple to clear it. Im using the nipple to actually connect to the resevoir because the bolt on the top of the stock h/e stripped. Im going to get a hack saw and notch a 1/2" wide section out for the nipple.
06 ss/sc, g85, S2, nates 2.9, dual pass +B, cai
Old Apr 20, 2008 | 08:57 PM
ColeJJones's Avatar
Bannned
you dont need to, just cut the nipple off if you need to. its only a drain off. then plug it with some silicon or something
Old Apr 20, 2008 | 09:22 PM
AcesNEights's Avatar
OK, So then what would be the easiest way to run this?
Old Apr 20, 2008 | 09:27 PM
QUAD442's Avatar
COLE JONES and others...the dual pass plumbing diagrams show a 1/4 line going back to the extra reservoir. If i am unable to run it from the stock h/e then i presume i will need to use the cxr to bleed air back to the reservoir. Im using the option B plumbing.
am i missing something??
Old Apr 20, 2008 | 10:42 PM
ItalianJoe1's Avatar
The reason they use the one on the factory H/E is that it is at a high point, where air gets stuck. Using one on the lower front mount H/E won't do anything, as air will still get trapped in the big H/E because its higher.
Old Apr 21, 2008 | 12:15 AM
Rodimus_Prime's Avatar
I thought it was an air bleed?
Old Apr 21, 2008 | 12:17 AM
cobaltstg2's Avatar
Originally Posted by ItalianJoe1
It will fuction, yes. It won't do anything useful.
In for pics of car with the bumper back on.
yeah i take some tommorw it does hang down but only on one side..my driver side.. but it is doing its job.. takes alot of coolant (beware)
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
