Ebay
Old Jul 14, 2005 | 01:26 AM
Kiss My SS's Avatar
Ebay
ever hear of this one -----> For Sale On Ebay
Vinny
Old Jul 14, 2005 | 02:32 AM
Shermen's Avatar
what the hell is that? and how does it make it produce more boost
Old Jul 14, 2005 | 08:42 AM
selfinfliction's Avatar
if i am correct i think you will need a piggyback or some type of way to reflash the pcm to get anymore boost out of it.
Old Jul 14, 2005 | 09:31 AM
Kiss My SS's Avatar
i think that is what it is or atleast what the guy is making it out to be. 2bar is usally an upgradechip. i dunno $80 buck though.
Vinny
Old Jul 14, 2005 | 09:46 AM
arsenal21's Avatar
I want to see a picture of it. Then I'll decide. For some odd reason it dosn't seem true.
Eeeh what the hell it's only $80.00. Someone buy it and try it out.
Old Jul 14, 2005 | 09:50 AM
Vinny
does anyone know if we have an afm or map? i've never really looked into the matter personally. i'm thinking with 12psi we would already have a two bar map, not sure what a one bar is capable of, accurately
i could be totally wrong on this matter, because i'm not educated on these things
Old Jul 14, 2005 | 09:53 AM
Kiss My SS's Avatar
i think someone was working on a piggyback but thats about it.
Vinny
Old Jul 14, 2005 | 11:20 AM
ray@revitup's Avatar
ok the cobalt ss has a mass air flow sensor and a map sensor a map sensor or manifold absolute preassure sensor is simply a resistor that meassures the difference between intake manifold preassure and atmosphere preassure. the computer uses this to monitor when the engine is under load to alter spark and ful mixture. if im not mistakking though the cobalt already has a 2 bar map sensor. what happens is this lets say a car has a 1 bar, once the manifold preassure reaches a certain point (boost) and computer cant monitor anymore your car will hit fuel cut.
Old Jul 14, 2005 | 12:49 PM
zinner's Avatar
Moderator Alumni
Its the map sensor that comes with the car OEM.
The MAP reads absolute pressure. So if your running 14.7 PSI of boost (1bar) plus the regular air pressure at sea level 14.7 PSI (1 bar) you have to 2 bars.
Old Jul 14, 2005 | 04:48 PM
dj4all's Avatar
How do you guys know all this stuff?? I'm thorughly impressed!!!
Old Jul 14, 2005 | 04:52 PM
i do it for a living
Old Jul 14, 2005 | 04:55 PM
dj4all's Avatar
Well, there you go. When can I make an appt to see you? How long is the drive from Toronto to Philly anyway?
Old Jul 14, 2005 | 08:09 PM
thanks for the calrification ray
Old Jul 14, 2005 | 10:33 PM
3fo893013L's Avatar
Eh, I won't trust anything peformance off Ebay. Sounds like a scam. Looks like a scam, it must be a scam
Old Jul 14, 2005 | 10:42 PM
clownhair's Avatar
its not a scam, its just a stock map sensor...............
It dosn't even say in the listing that it adds boost. It just says that it reads 2 bar.
Old Jul 14, 2005 | 10:45 PM
arsenal21's Avatar
In the ebay post it says that "it's capable of 14.5 lbs boost"
Old Jul 15, 2005 | 12:04 AM
zinner's Avatar
Moderator Alumni
Yeah thats all a 2 bar map can read. It's absolute not realitive so you have the 14.7 psi for the atmospehere (at sea level) and another 14.7 worth of boost on top of that.
Old Jul 15, 2005 | 10:03 AM
clownhair's Avatar
heres from the add
This is a brand new Map sensor for a 2005 Chevy Cobalt SS. It is capable of reading up to 14.7 lbs of boost. Plugs right into many gm vehicles after 2000. This is an original AC-Delco Part. Not a cheap aftermarket one.
says it only reads it.
Old Jul 15, 2005 | 10:19 AM
Originally Posted by clownhair
heres from the add
this would be good for someone with an na ecotec that wants to add a turbo.
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 21, 2015 11:57 PM
footballplaya3k
Wheels and Tires
Oct 8, 2015 05:24 PM
Tupp
Sep 30, 2015 08:18 PM
jcalvin1126
Sep 11, 2015 10:24 AM
