Erratic Idle
Old Mar 9, 2009 | 10:03 PM
  #51
drew1991sf's Avatar
that looks really bad, are u sure u should have more coolant in the option b tank is seemed very low
Old Mar 9, 2009 | 10:10 PM
  #52
daythecountrydied21's Avatar
idk i added more after that
i think it was bleeding air cause the level was going down but just for good measure i think im going to tear down again order a new intake gasket and 2 new laminovas and see wehre that gets me.
Old Mar 9, 2009 | 10:43 PM
  #53
Dainslaif's Avatar
Yeah, that definitely looks like a loose/disconnected hose or sensor.
Make sure you didn't pinch anything (hoses or wires) putting your stuff back in and double check all your electrical connections. If I remember right there's a plug somewhere down there that fits into two places (for some dumb reason) so make sure you have everything the right way.
That's not a tune issue by a longshot. That's something wrong in the bay.
Old Mar 9, 2009 | 10:45 PM
  #54
drew1991sf's Avatar
do u have warranty?
Old Mar 9, 2009 | 10:47 PM
  #55
hmm you think that may be it? i'm going to go to the dealer tomorrow and get a new intake gasket for good measure and tear it down agian and put it together.
if that doesn't work than laminovas will be ordered.
this plug you speak of, what are you referring to?
Originally Posted by drew1991sf
do u have warranty?
lol i've got an aftermarket one but this is my ******* fault so i'm going to do all in my power to resolve it myself before resorting to anything like that.
Last edited by daythecountrydied21; Mar 9, 2009 at 10:47 PM. Reason: Automerged Doublepost
Old Mar 9, 2009 | 10:55 PM
  #56
Dainslaif's Avatar
I don't even recall to be honest. I'm probably wrong about the plug.
I don't think new laminovas would be necessary unless you know you're leaking coolant into the IM. I'd wait until you tore it open before ordering them.
Old Mar 9, 2009 | 11:04 PM
  #57
Yeah I mean I did lose some coolant level tonight after i added some, i just attributed that to the air bleeding however, because my iat2's were seemingly correspondant with what they should be considering what was done, only reached 120 and stayed there after 20 or so mins of idling in the same spot, about 60 deg weather. no leaks and no coolant on the floor. The only thing that would lead me to believe in crying leak is that I keep getting a misfire code. I looked at where the misfires were at on the interceptor and they were all in cylinder 5,6,7,8? wasn't aware I had a v8 . I guess that code is bs then also?
Gonna start teardown again bright and early and contact the dealer when they open to see if they have a gasket hopefully and then throw all that back on and see if it gets me anywhere, if not i'm gonna look the the laminovas as that could be the only other problem =/.
Old Mar 9, 2009 | 11:14 PM
  #58
Dainslaif's Avatar
5,6,7,8 are false cylinders (idk why they didn't just program those out but whatever). As far as the misfire code, it's probably related to the funky idle. When my car had the bad tune and did RPM wandering it would throw a misfire after idling long enough.
Old Mar 9, 2009 | 11:18 PM
  #59
fair enough, basic troubleshooting told me to change plugs after that code, but what you said would make sense that changing them didn't really do anything.
could it be that i didn't tourqe the bolts to specifications? no torque wrench here so i just use the hand tighten rule and was just looking over the gm guide and has lots of tourqe levels..
Old Mar 9, 2009 | 11:30 PM
  #60
Dainslaif's Avatar
That might be, but I just sorta hand tighten most of mine as well. The only thing I'd be really worried about is (as you've mentioned) the IM bolts. If you didn't tighten them down enough and/or tore the seal a little that'd do it. Vacuum + bad seal = extra air -> rough idle.
That could POSSIBLY be a sticky as **** TB, but since it only started after you did the dual pass install I'm more likely thinking there's a leak somewhere.
Old Mar 9, 2009 | 11:36 PM
  #61
The im bolts as in the 2 studs, or all of the bolts attaching it?
I'm thinking that that is the most likley culprit as i already put the endplate on and it was 4 in the morning and i was just like alright lets get it on and go to bed haha.
I see also there's a certain sequence to tighten them, which I didn't do. I just did outsides in but not in the correct sequence. Sweet, I hope that we found my problem. Will let everyone know tomorrow if the dealer has my gasket in, if not in a few days then lol.
Thanks a lot for the suggestions paul.
Old Mar 9, 2009 | 11:45 PM
  #62
Dainslaif's Avatar
I'm still hoping it's something easy like a loose clamp somewhere, but either way I hope ya fix it. I hate having random gremlins like that.
Old Mar 9, 2009 | 11:49 PM
  #63
Unless something fell off down below I think everythings hooked up properly but, **** at this point i'll settle for taking the entire mani off and reinstalling again, time to pick up a torque wrench now i guess lol.
hope this is the break i've been looking for lol we'll see.
Old Mar 10, 2009 | 02:38 PM
  #64
lookie lookie what i found...
one loose bolt. i'm hoping this is my culprit.. will know tonight.
Old Mar 10, 2009 | 08:34 PM
  #65
VeNoM0713's Avatar
well, as much as i dont understand why.. i cleaned my TB and low and behold, my idle is now back to normal.. no more surging at a stop sign/red light.. its just so amazing how something so small can effect our idle.. thanks for the help btw.
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
n20saturn
Sep 21, 2015 01:50 AM
