Exhaust problems or codes?
Old Mar 29, 2010 | 01:41 PM
Tarheel62592's Avatar
When you do full exhaust on a Cobalt SS is it common to get any trouble codes? or are there any specific brands or parts that give you codes?
Old Mar 30, 2010 | 07:13 AM
Anyone?
Old Mar 30, 2010 | 07:44 AM
souchak2112's Avatar
Im not sure. I never heard of any throwing codes. Maybe wheb it comes down to the o2 sensor on the dp or possibly the headers.
Once you get a tune though you can have it tuned out
Last edited by souchak2112; Mar 30, 2010 at 07:44 AM. Reason: Automerged Doublepost
Old Mar 30, 2010 | 11:44 AM
InfraRedline's Avatar
You will most likely throw a P0420 cat converter inneficient code. Just tune it out and your good to go
Old Mar 30, 2010 | 12:36 PM
Do you get that cat code, even if you have a cat?
Old Mar 30, 2010 | 05:09 PM
Sometimes you do, depends on the cat. My Vibrant downpipe did when it was catted
Old Apr 7, 2010 | 06:10 AM
87gn06gto07irl's Avatar
If you go from a full 2.5 to a full 3 it'll mess with your o2 sensor readings and set a code. Time for a tune.
Old Apr 7, 2010 | 07:48 AM
Staged07SS's Avatar
Administrator
Administrator
this is not totally true. if you go from the stock downpipe to an aftermarket 3" downpipe you have the potential to set a p0420 cat code, but a 3" catback will not cause a code to be set.
your 02 sensors are in the header/manifold, and in the downpipe after the cat. so if you increase the flow in that area beyond the set parameters in your tune a CEL is possible. a catback exhaust (2.5", 2.75", 3") will not cause a CEL.
brandon04
Oct 21, 2015 07:04 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
