Exhaust rattle with zzp downpipe?
I finally figured out what this buzzing noise was that I could hear in the car when I would accelerate sometimes. It was getting common enough that when I started my car yesterday I could clearly hear the exhaust rattling while I stood outside my car. The only thing I have done to it was a zzp 3" catted downpipe and it still has the stock catback and exhaust manifold on. Nothing appears to be loose, anything I should look at while I have it up in the air?
check the heat shield, its probably touching somewhere, you can bend the stuff pretty easy so its farther away from the pipe. mine did it too. does it sounds like this? you can hear it from :11 to :13
YouTube - ‪Cobalt ss exhaust‬‏
Last night I had it up in the air and bent away the heat shield next to the converter because it seemed like it would be touching there since it was so close. Well, I left for work this morning, still same rattle, and it seems to be getting worse, now i can hear it in every gear while accelerating. Get home tonight and don't notice anything with the heat shield so I start hitting the downpipe with my hand and it seems like something was actually inside the dowpipe. The downpipe is fairly new (March 17th of this year) and Magnaflow makes good stuff but what are the chances of the cat actually falling apart from the inside? I know stock ones will do this but a new one that only a few months old??
