First Oil Change
First Oil Change
What mileage was on your car when you got your first oil change? I figured since synthetic came in the car it had to be pre broken in, because synthetic oil is not a good break in oil. I figured 3,000 would be adequate for the first one, but whats everybody elses opinion?
just hit 4000 on mine and getting it changed next tuesday compliments of the dealer. Ii dont really trust them but they also pay for my first 4 oil changes so ill double check their work and deal with it. After that, ill do my own
Well see i've got 1400 miles on my car so far, I was just wondering if it would be okay to wait until 3,000. I figured that it would be assuming that the engine was already broken in. Becasue honestly if our engines wasn't broken in and GM put synthetic oil in from factory then our engines would never break in at all.
Originally Posted by johnkb8
X2 for me
There shouldn't be that many shavings in the first place man. Its almost impossible to have shavings in the oil with syntehtic because it makes everything too slippery. Thats the reason the engine had to be broken in at the factory with dinosaur oil. This is the reason I believe I'm going to wait until 3,000 miles. Also if there are any shavings they shoudl be minimal and picked up by the oil filter.
Just follow the darn oil life meter....you'll save money....car won't be any worse for it.
Plus, its better in terms of dumping out old oil for recycling...less garbage oil.
The filter will catch "shavings", and even most particulate <sp> matter...that's what its for....
Betcha if you take your old filter, and run a killer magnet over it, it will come back with...nothing....that means the filter held the stuff it should....
lol, i suck. ive got 5565 on the odometer and havent changed it yet... DIC still says 28% life so until it says change, i wont change... if the DIC says no worries, then its covered under waranty if my **** breaks. I<3 new cars!
I agree
yeah I'm going w/ the DIC.... hahaha. No seriously, the DIC monitors your driving style (supposedly) and determines the time between changes. And if following the DIC works w/ my warranty.... why bother.
Well, considering it takes like 6 and a half quarts and its only 2 liters worth of displacement, and not to mention it is a highly efficient modern engine and runs on synthetic, you can afford to be a little lazy on them.
Personally i have them change the oil at 50% (about every 4500 miles) on the oil life meter, but thats just because i'm paranoid and want my oil to be in top performing condition. I bet you could run it to 8000 miles easily without any viscosity related engine wear.
Originally Posted by Forseti
Filter should be in lock step with the DIC...I didn't think the owners manual said to change it more often....
I am just paranoid as well, and want to make sure my engine is as protected as possible.
importkiller
Sep 30, 2015 07:18 PM
roth
Sep 26, 2015 12:16 PM
