First Oil Change
Old Sep 6, 2006 | 01:53 PM
L.P.'s Avatar
First Oil Change
What mileage was on your car when you got your first oil change? I figured since synthetic came in the car it had to be pre broken in, because synthetic oil is not a good break in oil. I figured 3,000 would be adequate for the first one, but whats everybody elses opinion?
Old Sep 6, 2006 | 01:54 PM
ItalianJoe1's Avatar
I went about 1800
Old Sep 6, 2006 | 01:58 PM
splink's Avatar
i slept in a bit and did it at 5000...i like to go at 3000, regardless of what kind of oil
Old Sep 6, 2006 | 02:08 PM
Tomtwtwtw's Avatar
You are correct in assuming the engine is already broken in. The rest of the drivetrain components aren't, so it's still advised to take it easy on the car for a while at first, though. That said, it's perfectly safe to go by the OLM from day one, but if you need to change it sooner for peace of mind, then go for it. Some people feel it's worth the price.
Old Sep 6, 2006 | 02:10 PM
CTCOBALTSSS's Avatar
I did my first oil change at 500 miles, right after the "break in period".
Old Sep 6, 2006 | 02:11 PM
cobi's Avatar
just hit 4000 on mine and getting it changed next tuesday compliments of the dealer. Ii dont really trust them but they also pay for my first 4 oil changes so ill double check their work and deal with it. After that, ill do my own
Old Sep 6, 2006 | 02:13 PM
johnkb8's Avatar
X2 for me
Old Sep 6, 2006 | 02:22 PM
L.P.'s Avatar
Well see i've got 1400 miles on my car so far, I was just wondering if it would be okay to wait until 3,000. I figured that it would be assuming that the engine was already broken in. Becasue honestly if our engines wasn't broken in and GM put synthetic oil in from factory then our engines would never break in at all.
Old Sep 6, 2006 | 02:28 PM
Originally Posted by johnkb8
X2 for me
You know it. The best part is I told them it was mandatory to do the oil change after 500 miles because it's GMs recomended break in period and they believed me. They tried to charge me for it and I said no way, not for something that is mandatory from GM. So they gave it to me for free. What tools. I recomend an oil change after your first 500 miles because this way any shavings or anything from break in will be flushed out quickly.
Old Sep 6, 2006 | 02:29 PM
drdaley's Avatar
3000 for the first now every time the car tells me to...
Old Sep 6, 2006 | 02:33 PM
L.P.'s Avatar
There shouldn't be that many shavings in the first place man. Its almost impossible to have shavings in the oil with syntehtic because it makes everything too slippery. Thats the reason the engine had to be broken in at the factory with dinosaur oil. This is the reason I believe I'm going to wait until 3,000 miles. Also if there are any shavings they shoudl be minimal and picked up by the oil filter.
Old Sep 6, 2006 | 02:35 PM
Oh yeah absolutely bro. There would be minimal shavings if any at all. I just did it as a precausion in case there was. I'm paranoid. It's not like it will hurt it you know.
Old Sep 6, 2006 | 02:55 PM
Forseti's Avatar
Just follow the darn oil life meter....you'll save money....car won't be any worse for it.
Plus, its better in terms of dumping out old oil for recycling...less garbage oil.
The filter will catch "shavings", and even most particulate <sp> matter...that's what its for....
Betcha if you take your old filter, and run a killer magnet over it, it will come back with...nothing....that means the filter held the stuff it should....
Old Sep 6, 2006 | 03:07 PM
SchwarzCamaroRS's Avatar
lol, i suck. ive got 5565 on the odometer and havent changed it yet... DIC still says 28% life so until it says change, i wont change... if the DIC says no worries, then its covered under waranty if my **** breaks. I<3 new cars!
Old Sep 6, 2006 | 03:19 PM
Asstyme's Avatar
I agree I'm going with the DIC also, I'm at 4600 miles and at 28%.
Old Sep 6, 2006 | 03:50 PM
rnjmur's Avatar
I did my first oil change at 50%. Now I do my oil changes when the DIC tells me, with the exception that I change the oil filter at 50%.
Old Sep 6, 2006 | 04:01 PM
campo165's Avatar
well im at 5400 miles and still havent changed it yet...
Old Sep 6, 2006 | 05:16 PM
Forseti's Avatar
Filter should be in lock step with the DIC...I didn't think the owners manual said to change it more often....
Old Sep 6, 2006 | 05:25 PM
suburbanrobot's Avatar
yeah I'm going w/ the DIC.... hahaha. No seriously, the DIC monitors your driving style (supposedly) and determines the time between changes. And if following the DIC works w/ my warranty.... why bother.
Old Sep 6, 2006 | 05:30 PM
OniMirage's Avatar
3k for me then after that I have followed the meter and change now ever 10~14% life left.
Old Sep 6, 2006 | 05:45 PM
LandonElf's Avatar
Well, considering it takes like 6 and a half quarts and its only 2 liters worth of displacement, and not to mention it is a highly efficient modern engine and runs on synthetic, you can afford to be a little lazy on them.
Personally i have them change the oil at 50% (about every 4500 miles) on the oil life meter, but thats just because i'm paranoid and want my oil to be in top performing condition. I bet you could run it to 8000 miles easily without any viscosity related engine wear.
Old Sep 7, 2006 | 01:14 AM
rnjmur's Avatar
That maybe true, but until I see some proof that the filter can last more then 3000 miles, I will assume it has the typical life of any oil filter. That means changing by 3000 miles. In all synthetic oil tests the Mobil 1 was able to easily go 12,000 miles before any sign of breakdown. However, during the test the filter was changed every 3000 miles and 1/2 a quart of new oil added to make up for the oil loss. If you factor out the added oil, you should be able to easily pull 8000 miles between oil changes. But that still takes into account the filter being changed at 3000 miles. If not changing the filter I don't know if I would trust it to go more then 5000 without an oil change.
I am just paranoid as well, and want to make sure my engine is as protected as possible.
Old Sep 7, 2006 | 01:27 AM
mi6_'s Avatar
Changed mine at 1500 Kms! Better safe than sorry. Though even I admit, it probably would have been fine to go longer.
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
roth
Sep 26, 2015 12:16 PM
