fuel milage
Old Jul 6, 2010 | 08:01 AM
DEZZIE41's Avatar
fuel milage
ive noticed over the last 2 days my fuel milage has gone to ****..ive been driving it easy and not speeding..for example i went to and from work then to work this morning and it burnt a eight of a tank and then was no traffic in front of me is this normal i take it cause it never burnt that much to go to work in one day before also to and from work is onny 35\kms
Old Jul 6, 2010 | 12:42 PM
rnjmur's Avatar
It is impossible to tell. Did you fill the tank all the way? Sometimes the gas pumps will shut off early and you could have a gallon (3 or 4 litres) less than usual. The only way to really tell if fuel mileage is getting worse is to start logging your distance and how much fuel you put in the car when you fill up and start to calculate fuel mileage yourself. If you keep track and do see an actual mileage drop then it is time to do some tune up maintenance, i.e. plugs and fuel filter.
Old Jul 6, 2010 | 12:48 PM
Staged07SS's Avatar
Administrator
Administrator
Check the air pressure in your tires.
My fuel mileage was getting crappy at one point, and I found the air pressure in my tires to be 1-2lbs below the recommended level. I brought my tires back up to 32lbs each, and my fuel mileage went back to normal.
Old Jul 6, 2010 | 12:53 PM
JM Auto Racing's Avatar
my average when i use the same fuel stationsaround 38 highway and about 18-24 city, im tuned lean on the cruising side. and a little richer in city for cooler combustion.
I own a 2006 ss sc. built motors and so forth.
Last edited by JM Auto Racing; Jul 6, 2010 at 12:53 PM. Reason: Automerged Doublepost
Old Jul 7, 2010 | 01:25 AM
DEZZIE41's Avatar
its got new plugs and fuel filter reg oil change, i did put a cai on last year maybe the filter ??
Old Jul 7, 2010 | 02:35 AM
Erick161's Avatar
What he said, I noticed a big difference when I forgot to pump my tires back up after I left the track. I run mine pretty high though.
Old Jul 7, 2010 | 10:56 AM
If you are a sc car, check your IC pump. because if it is not working your mpg will go down since you are running warmer iat2z.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
