funny sounds thats not so funny
Old 06-05-2009, 09:57 PM
NOLAGSS's Avatar
so i have noticed this funny sound when i fist start my car... sounds like pinging but its only when its cold. once the engine warms up it goes away. im using 5-w30 valvoline syntech. didnt bother me that much till today.. i changed my oil and have a buddy rev the engine ever so slighty till i could pin point the sound..... hears were it gets interesting, right by the timing cover at about 2-3k it sounds like rocks in the engine. but only between these rpms. my thought is timing chain guides idk please help any input... mods in my sig
Old 06-05-2009, 10:16 PM
Dowden's Avatar
I had a similar noise, when the car was started cold then once it warmed up it went away, I brought it to the dealership and they said there was a leak in the exhaust manifold gasket! and when the car warmed up the metal expanded and closed the hole. I Had it replaced and the noise is gone. Im not sure if its the same problem just thought Id throw it out there.
Old 06-05-2009, 10:20 PM
NOLAGSS's Avatar
yeah mine almost sounds like an exhaust leak as well and its coming from that area..... i only have 50k on the car so idk what the other sound could be
Old 06-06-2009, 08:26 PM
NOLAGSS's Avatar
so i talked to a technician at work today and they said its a belt chirp.. makes sence because at times i only hit 9-10 psi so i believe i have belt slip..
Old 06-07-2009, 02:34 AM
Flatgod's Avatar
Everything you have described sound like what happened to my car. Exhaust leak. For the longest timed I thought it was a belt. The gm tech thought it was a belt. But in the end it was an exhaust leak.
Old 06-07-2009, 07:02 PM
HunterKiller89's Avatar
you would only experience belt slip under WOT. sounds to me like your saying you hear the noice only on a cold engine after startup, which i assume means you're hearing it at idle.
Old 06-16-2009, 01:03 PM
NOLAGSS's Avatar
yes i hear it at idle and in first gear when i take off but like i said its only when the engine is cold
Old 06-16-2009, 01:04 PM
NOLAGSS's Avatar
Old 06-16-2009, 01:05 PM
NOLAGSS's Avatar
Old 06-20-2009, 08:39 PM
NOLAGSS's Avatar
well now it does it every time i start the car almost... if i let it sit for 20-30 minutes and start it up the noise is there.. its getting louder and scaring me know. i held a pry bar up to my manifold and listening through the handle its loudest on the manifold.. sounds like a crazy idea but try it the prybar actually magnifies noise. but is 20-30 minutes long enough for the gasket to cool down and shrink???
Old 06-21-2009, 12:04 AM
ssyellow's Avatar
http://www.youtube.com/watch?v=CYDsci-EBLg
meh? lifters...
Old 06-21-2009, 01:47 AM
NOLAGSS's Avatar
yep theres the noise... so what now
turbochargedss2012
09-20-2023 12:17 PM
biniecki
10-25-2015 02:23 PM
jimbofug007
10-02-2015 12:06 PM
DANRICKARD
10-01-2015 12:08 AM
roth
09-26-2015 12:16 PM
Quick Reply: funny sounds thats not so funny
