FX400 6 puck installed...thoughts...warning long
Old Jun 11, 2006 | 06:59 PM
djt81185's Avatar
Originally Posted by SS_SC_Cobalt
question is, has anyone installed their clutch without changing the throwout, if it works fine at that point then it is definitely a bleed problem....
it is not a bleed problem...we bled the system better than gm recommends...it is a design problem
Dan
Old Jun 11, 2006 | 07:30 PM
06black's Avatar
is this a problum that ALL aftermarket clutch's are going to suffer??
are all the stifer clutch's going cause such problums????
is everybody haveing problums with there aftermarket clutchs???
Old Jun 11, 2006 | 07:34 PM
max_boost's Avatar
I don't seem to be having these problems, but I've never taken it to a track either. I definently don't have the issues Dan is describing.
Old Jun 11, 2006 | 07:56 PM
djt81185's Avatar
The not being able to speedshift and grinding...most likely since it seems the stock system is inadequate to actuate an upgraded clutch
Dan
Old Jun 11, 2006 | 07:59 PM
06black's Avatar
dam thats funny....
the 2 other guys i know that have aftermarket clutch's dont have this problum BUT the issue's hes talking about as far as the lines flexing and sich i can totaly see as a possibility.
Old Jun 11, 2006 | 08:11 PM
FAST06SS's Avatar
I left my stock slave cyliner in so it eliminates that.
For you guys that don't think you have a problem, try this, first put the into 1st or 2nd gear with the clutch depressed and rev the motot to 6K + and see if it tries to move at all.
Then go out and rev to 7K rpm and shift so fast that your hand is a blur! I mean beat on it. Then tell me if you shift perfect into 2nd everytime w/o a problem. I bet million bucks you'll have a problem.
Old Jun 11, 2006 | 08:15 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
So are you saying "don't change the slave cylinder?"
Old Jun 11, 2006 | 09:58 PM
djt81185's Avatar
it has been changed and left the same and problems have been had both times.
Dan
Old Jun 11, 2006 | 10:02 PM
distillion's Avatar
i will not buy an aftermarket clutch until these problems are resolved, sorry to hear about all the probs everyone is having.
Old Jun 11, 2006 | 11:28 PM
retrop's Avatar
I had the 1-2 problem with the stock clutch near 7K the other day, wouldn't go into second w/o the rpm dropping below 6K, just glad i didn't release the clutch or it would have been messy. This was the first time i really ran out 1st gear in the car.
Old Jun 12, 2006 | 10:16 AM
  #36
Saki XL's Avatar
**Edited**
Changed my mind... I'm just going to sell the clutch for now, I have other things I need more. Anyone interested in a CM FX400 Clutch, UNUSED, still in the original package, unscathed... PM Me. Asking is $500, but if you have any better offers I'll go with them.
06MetallicBalt
Jul 20, 2025 08:47 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
importkiller
Sep 30, 2015 07:18 PM
z28addiction
Sep 28, 2015 12:03 AM
