GM I/C pump
GM I/C pump
I am a pontiac grand prix owner that is planning on intercooling. I have pieced together everything so far. I have on problem- I bought the cobalt water/Intercooler pump from Gmpartsdirect, and see that it has 2 mounting "studs". Question is, where does this go? Is there some kind of bracket or something I need to buy with this? Any help would be greatly appreciated.
this is the pump
and these are the studs I am referring to:
this is the pump
you can get the mount bracket for about $40 at Gmpartcheap.com i believe, i still have mine, but don't want to sell it if i were to ever go back to the stock pump. Otherwise, my aftermarket one is mount to the frame in front of the engine. Made an aluminum bracket then strapped it on with 3 worm clamps and put some silicon padding inbetween the metal parts, very easy.
yeah, its a Jabsco 50830 12v low pressure centrifugal pump, about 2-3 times the flowrate of the stock pump.
pump description
it seems to work great, just hook it into the 12v wiring for the old pump and find a mounting point.
pump description
roth
Sep 26, 2015 12:16 PM
