GM I/C pump
Old Jun 16, 2008 | 05:21 PM
Pimp Prix's Avatar
GM I/C pump
I am a pontiac grand prix owner that is planning on intercooling. I have pieced together everything so far. I have on problem- I bought the cobalt water/Intercooler pump from Gmpartsdirect, and see that it has 2 mounting "studs". Question is, where does this go? Is there some kind of bracket or something I need to buy with this? Any help would be greatly appreciated.
this is the pump
and these are the studs I am referring to:
Old Jun 16, 2008 | 05:51 PM
Area47's Avatar
Rent me! per hour
it fits in the factory mount under the intake manifold on the lsj.
Old Jun 16, 2008 | 05:53 PM
Pimp Prix's Avatar
is this a part that that I can use on my car? or is there a spot on the LSJ that is pre-drilled to accept this?
Old Jun 16, 2008 | 08:22 PM
qwikredline's Avatar
just clamp it around that rubber sleeve and mount it up...
Old Jun 16, 2008 | 08:28 PM
mrphoto103's Avatar
From: Voted by the people, most likely to get pulled over by a cop
You will have to fabricate it somewhere, that mount is pretty proprietary to the lsj setup
Old Jun 17, 2008 | 01:29 PM
LopsidedJester's Avatar
you can get the mount bracket for about $40 at Gmpartcheap.com i believe, i still have mine, but don't want to sell it if i were to ever go back to the stock pump. Otherwise, my aftermarket one is mount to the frame in front of the engine. Made an aluminum bracket then strapped it on with 3 worm clamps and put some silicon padding inbetween the metal parts, very easy.
Old Jun 17, 2008 | 01:32 PM
SS33's Avatar
^^Which aftermarket pump did you go with? Bosch?
And how do you like it? Aside from mounting is it plug N play?
Old Jun 17, 2008 | 01:37 PM
yeah, its a Jabsco 50830 12v low pressure centrifugal pump, about 2-3 times the flowrate of the stock pump.
pump description
it seems to work great, just hook it into the 12v wiring for the old pump and find a mounting point.
Old Jun 17, 2008 | 05:06 PM
Pimp Prix's Avatar
thanks guys. You've been more helpful than the folks on my own forum
DarrenGC
Dec 24, 2021 01:55 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
