GM Racing Exhaust Ported Cylinder Head
Old Nov 5, 2013 | 11:11 AM
InfraRedline's Avatar
I have a 3 day weekend coming up.
I'm going to start tearing her apart this upcoming Monday. I hope to have the stock head off the car by the end of the day.
I need to order a new valve spring compressor tool (sold mine last year), and then I will transfer the supertech springs & cams over to the gmr head.
Sounds like a solid plan. These cars are fun to work on, at least when you are doing it because you want to, not because you have to
Old Nov 5, 2013 | 11:12 AM
Staged07SS's Avatar
Administrator
Administrator
Haha, good point!
I had all intensions of just throwing the car cover on her this winter.
Slight change of plans, lol.
Old Nov 5, 2013 | 12:47 PM
Staged07SS's Avatar
Administrator
Administrator
Parts list:
Cylinder Head Gasket 2.0 LSJ 55352039
Ecotec Head Bolt 90537691
Ecotec Head Bolt 24407225
ARP Ecotec Timing Chain Tensioner Bolt Set 11588522R
Ecotec Timing Chain Tensioner 12608580
Loctite 510 Flange Sealant
Loctite 277 Tread Locker
CMD #3 Extreme Pressure Lube
Kent Moore J-43649 Valve Spring Compressor
^Updated in 1st post as well.
ARP head studs are not in the budget.
My car will only be pushing 15 psi (about 16 psi currently) more than likely, so the stock head bolts should be more than fine.
Old Nov 5, 2013 | 12:53 PM
jonathan923's Avatar
that is an awesome setup man. Ive always admired the way you do things on your car. should be beast once done! good luck on the build!
Old Nov 5, 2013 | 12:55 PM
Staged07SS's Avatar
Administrator
Administrator
Thanks for the kind words man.
I try to install parts to exact GM specs for durability purposes.
Old Nov 5, 2013 | 12:56 PM
Bluelightning's Avatar
Got Bewst?
Finally! Looking forward to an after pull to see the difference the head made.
Old Nov 5, 2013 | 12:58 PM
Staged07SS's Avatar
Administrator
Administrator
I cant wait!! Should really let the cams and H62 shine.
Old Nov 5, 2013 | 01:01 PM
who do you get tuned by staged?
Old Nov 5, 2013 | 01:03 PM
Got Bewst?
GM lol
philzoot007's Avatar
i have a gmr head also. ur gonna love it......had it for a while now.
for the extra 60 bucks get the arp studs. then if u crack the head again u dont pay 60-80 bucks for stock bolts all over again....
  #36
Staged07SS's Avatar
Administrator
Administrator
I dont, lol.
I'm running a straight GMR S3 calibration. Maybe after all is said & done, I will have the tune tweaked a bit.
Make a noticeable difference?
GM lol
This, haha.
Old Nov 5, 2013 | 01:08 PM
  #37
Got Bewst?
Have you noticed a change in your afr or any knock as you've bolted things on over the years?
Old Nov 5, 2013 | 01:09 PM
  #38
blueLNFftw's Avatar
I need a ported head
Old Nov 5, 2013 | 01:11 PM
  #39
Staged07SS's Avatar
Administrator
Administrator
AFR leaned out a tad after the cams, but I have zero knock.
You can buy my stock head and have it ported
Old Nov 5, 2013 | 01:26 PM
  #40
574's Avatar
574
I forgot you still have N20 jumper wires to hook up. This car will be very respectable with that complete
Old Nov 5, 2013 | 01:29 PM
  #41
list copied to my list
Old Nov 5, 2013 | 01:36 PM
  #42
Staged07SS's Avatar
Administrator
Administrator
I sure do. That will have to wait till next winter though.
My budget will be shot after everything is said and done, lol.
Good stuff
Old Nov 5, 2013 | 01:37 PM
  #43
blueLNFftw's Avatar
Price on stock head?
Old Nov 5, 2013 | 01:38 PM
  #44
Staged07SS's Avatar
Administrator
Administrator
I'll let you know once I remove it from the car.
I may sell it with brand new stock cams & valve springs that will be removed from the GMR head. I'll keep you posted man.
Old Nov 5, 2013 | 01:39 PM
  #45
and all this is with 42s? or what fuel system are you running? i havent gotten that part
Old Nov 5, 2013 | 01:55 PM
  #46
Staged07SS's Avatar
Administrator
Administrator
Yep, all this with 42's. Injector pw's are high no doubt, but no problems in the 6 years they've been installed.
Time attack ran the gmpp 42's and reved out to 8k. Of course on a slightly modified fueling system, but I've had no issues with my current setup.
Remember, I don't run a redic small pulley. Just the good ol GMR S3 2.992" pulley. The build book engine, which is my engine almost to the exact spec (minus the 10:1 compression ratio), ran everything I have on a GMR S3 PCM with more aggressive cams.
Old Nov 5, 2013 | 01:57 PM
  #47
fuel up and pulley down!
Old Nov 5, 2013 | 02:01 PM
  #48
i have a set of those jumper wires if u wants them. brand new. i had it with the trifecta pcm and stage 3 tune. bought an extra set incase i fubared the install lol.
op. yes noticeable difference. also reving to 8 grand helps out lol.
  #49
Staged07SS's Avatar
Administrator
Administrator
No need with the H62. Makes very good power with the S3 pulley.
I'm not going outside of my GMR/GMPP build. I want to keep her in spec with what I've been working to build over the course of a few years.
If I was going to run race gas 100% of the time, I would step up and purchase 10:1 pistons, but this is still a daily driven car (nice weather of course).
Nice!!
I have the jumper wires. Was going to install nitrous this winter, but the GMR head took over that build, haha.
Old Nov 5, 2013 | 02:06 PM
  #50
ItalianJoe1's Avatar
Love it. I always wanted one for my setup but never had the free funds. Looking forward to results
