GM Racing Exhaust Ported Cylinder Head
Old Nov 13, 2013 | 12:18 AM
  #101
Staged07SS's Avatar
Administrator
Administrator
True true.... Everything will be checked and inspected before I reassemble. There are things to look for on guides that may lead to replacement. I'm interested to see if there has been any increased wear since I installed the cams.
Old Nov 13, 2013 | 12:23 AM
  #102
speedbugy996's Avatar
Your single pass will be nice. reworking the whole deal. we been scrapping a manifold looking at stuff lol
I'm looking forward to it John, also that 4.45 final gear.
Old Nov 13, 2013 | 12:28 AM
  #103
I was just doing preventative maintaince on the timing system at 60, 000 miles, found the cracked guide and then stumbled on the the GMR head when talking with John. Been very happy with my luck it's worked out well, also put the Powel pcv upgrade on along with the head and that's kept things nice and clean intakewise, idle surge improved. it still acts up some, but I think that's just the o2 sensor being lazy in the k&n cai housing.
Old Nov 13, 2013 | 12:38 AM
  #104
05RLS2's Avatar
I have the same amount of miles as you, but have never inspected anything timing related. Heck, I have never even had the cam cover off. Was your guide starting to crack, or already cracked in half. Usually whenever there is chain that has developed slack or if the guides are worn its noticeable, and you can hear an audible slapping from the chain. Did you hear any noises prior to doing maintenance?
Old Nov 13, 2013 | 12:42 AM
  #105
No, no symptoms of a problem, but with 10% of the miles being track miles I figured check it early and I was glad I did guide was cracked but hadn't failed yet.
Old Nov 13, 2013 | 07:35 AM
  #106
Powell Race Parts's Avatar
what i find with a broken black guide bolt, you get a ticking like a noise lifter that comes and goes at idle. makes sense the black guide gets broken and then it flops around a bit. Speedbuggys was cracked and the fastener bolt was not broken...
Old Nov 13, 2013 | 07:37 AM
  #107
Staged07SS's Avatar
Administrator
Administrator
All my guides and timing components were mint at 48k miles when I installed my cams and valve springs last winter.
I put about 5k on the car this spring/summer/fall and will inspect it all again when I begin the gmr head install.
Old Nov 13, 2013 | 09:05 AM
  #108
mrbelvedere's Avatar
Why not, nothing wrong with stock cams.
stock cams are decent cams but there are better choices
I agree. I have had built a LSJ engine for customers with TVS and a very nice ZZP stage 2 cam set, and the engine made 323 whp on street pump gas. I make with stock cams 320 whp on race gas and 305 whp or street pump gas.
difference is , I have very nice torque band very good on the track and a rev band that starts with peak torque at 4500 ( more peak torque than the stage 2 ZZP and more peak torque than Mr. B shows, and that torque on cams may be a higher peak.) Cross over is about 800 rpm less with the stock cams.
So this makes the car very driveable. Admittedly I run single pass, and I drive like a granny on the street.
The valve train wear on the stage 2 cam set up is pretty hard. On Time Attack, BITD GM tried really hard to get the 272 cams to work, and at the 11th hour with the Time Attack event coming up, and many blown engines in dyno testing, the decision was made to go back to stock cams. LSJ stock cams are very well thought out imho.
There are lots of folks like cams, and I wish them all well with the LSJ. That said,
Speedbuggy, I am with you. And the OP. lol
I can say this my car is 100% easier to drive then a stock cammed car on the street it has a lot more power(even more then the zzp stg2 cams) every where and the car is really smooth
If I can get to 305is on 93 octane I'll be happy with that, nicely balance for the track on 235 tires and still a good daily driver. With the new trans going in next week and the 4.45 final I think I'll be good. Single pass is also in the works before spring.
the only way you will even come close is to switch the fuel source to e85 and realy lean on it or put cams in it or buy a tvs
thats what Mr. B has just done right?His cams are his, not ZZP stage 2 but his and stage 2 are a lot closer than stock cams.
I did a mix its not straight race fuel I decided to stop where its at in favor of a fuel change e85 is easier on the engine then race fuel and enlarges the tuning window by 10 fold
Originally Posted by JapEatr
Im thinking of trying mrb cams next season
Replace your timing chain and components Jeff!!!! We have had a few cars lately eat the guide bolts in a bad way on our team
they are better then zzp cams
Old Nov 13, 2013 | 01:31 PM
  #109
I love the posts saying my cams are better than his cams etc.
so far on engine on your cams has produced around 330/250 which is roughly 3% more than a zzp stage 2 we did here on pump gas. different dynos different days, I would say its a wash.
good luck with developing your build; it looks promising, once you figure out how to deal with the maf scaling. Arm can help you I expect.
Old Nov 13, 2013 | 01:39 PM
  #110
Staged07SS's Avatar
Administrator
Administrator
Woahhhh hey guys.... no need to get touchy about cams in my thread
Powell, where does your car make peak power with the stock cams?
Where did Time Attack make peak power with the stock cams (if you can remember)?
I have the Time Attack blower, and assume she can produce power past 7k on the stock cams with the GMR ported head. On the stock head, power peaked around 6800 rpm.
Old Nov 13, 2013 | 01:59 PM
  #111
maf scaling is handled I chose not to push it on race fuel its time for e85 and how I know the cams are better they are moving a lot more air then the zzp cams
its not going to produce much past 7 no matter what blower you use
Last edited by mrbelvedere; Nov 13, 2013 at 01:59 PM. Reason: Automerged Doublepost
Old Nov 13, 2013 | 05:57 PM
  #112
Just for info, the Harrop TVS keeps pulling past 7k to 8k, and the power curve doesnt drop. And thats with stock cams..... That said, its just not realistic to rev that high, it costs too much in upkeep.
OP I will go look for dyno sheets this weekend. Too much to do right now...
Last edited by Powell Race Parts; Nov 13, 2013 at 05:57 PM. Reason: Automerged Doublepost
Old Nov 13, 2013 | 06:01 PM
  #113
Staged07SS's Avatar
Administrator
Administrator
Thank u John.
Old Nov 13, 2013 | 08:40 PM
  #114
blower will cams wont
Old Nov 13, 2013 | 08:50 PM
  #115
yup with M62 I found at 6800 the engine signed off and went on break. The curve plummeted.as in fell to earth. lol
the time attack ran to 7800 iirc on the money lap. But Heinricy drove to win, and he would always round out to the higher whole number
8k lol
Old Nov 13, 2013 | 11:19 PM
  #116
Staged07SS's Avatar
Administrator
Administrator
8k lol
How I wish that car was still around today.
Old Nov 13, 2013 | 11:31 PM
  #117
i never could find much info/pictures/footage on that car besides in the build book and people.mentioning it as the god of all cobalts. anyone got a lead on this thing?
Old Nov 13, 2013 | 11:42 PM
  #118
andrewcarr1993's Avatar
I'd imagine Powell has a bunch of information and pictures he could upload if he really wanted to.
Old Nov 13, 2013 | 11:50 PM
  #119
i het!
john, a request from me that im sure.others would piggyback on: make a thread all about that car.
ok, /thread tangent.
car still going under the knife this next week?
Old Nov 14, 2013 | 07:04 AM
  #120
for the road course it was
Old Nov 14, 2013 | 07:06 AM
  #121
Staged07SS's Avatar
Administrator
Administrator
i het!
Yep. Sure is.
Might start tomorrow afternoon after work
Sadly the car no longer exists
Don't worry, it's heart will live on in my car, haha.
Here's a nice article on it: http://www.grand-am.com/News/GA_News...-speed-tv.aspx
Here's the only video I've seen of the actual T/A car:
Old Nov 15, 2013 | 08:50 AM
  #122
Staged07SS's Avatar
Administrator
Administrator
Added a new part to the list.
GUIDE 13104978
Speedbuggy & Bluelightning got me thinking about changing the plastic chain guide. It's only a $14 part, why not?
I will of course inspect the other chain guides for wear, as well as all the timing components, but since it is nearly impossible to spot a hairline crack in plastic, I figured I better change it.
Old Nov 15, 2013 | 01:14 PM
  #123
Bluelightning's Avatar
Got Bewst?
Good call man. Don't want this
https://www.cobaltss.net/forums/2-0l...-broke-302543/
Old Nov 15, 2013 | 01:25 PM
  #124
Staged07SS's Avatar
Administrator
Administrator
I remember that thread now.
I def don't want that happening.
Old Nov 15, 2013 | 01:42 PM
  #125
ThexGovenor's Avatar
go with the stage1 cams. it will only help with the ported head. You already have them, why not toss them in? Anyway cool snag!
