GM Racing Exhaust Ported Cylinder Head
Old Nov 15, 2013 | 02:00 PM
  #126
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by ThexGovenor
go with the stage1 cams. it will only help with the ported head. You already have them, why not toss them in? Anyway cool snag!
I'm going to swap the S1 cams over to the ported head, along with my supertech valve springs. I was just tossing ideas around with the stock cams.
Old Nov 15, 2013 | 02:12 PM
  #127
ThexGovenor's Avatar
Good stuff
Old Nov 16, 2013 | 03:17 PM
  #128
05RLS2's Avatar
Yep. Sure is.
Might start tomorrow afternoon after work
Sadly the car no longer exists
Nice, I'll be checking in on this.
I thought that the Time Attack car was sold at the Barrett Jackson auction a few years ago. I don't know who has it now or what happened from there. Hopefully it wasn't parted out and crushed.
I have seen the Time Attack Car and the 272 Concept a couple times at shows, and they are both awesome and built with quality engineering. My goal with my car was to do that same as you, build it to GM style specs like the Time Attack car, but mine would be the Redline version that GM never did. It has got a LONG ways to go on that though
Old Nov 18, 2013 | 09:21 AM
  #129
Staged07SS's Avatar
Administrator
Administrator
Yep, it was sold at auction, but ended up being destroyed.
Just had this convo a few months back. It's a shame.
Old Nov 18, 2013 | 09:24 AM
  #130
what was the reason for destroying?
Old Nov 18, 2013 | 09:26 AM
  #131
Staged07SS's Avatar
Administrator
Administrator
No idea. I was told this by a member who tracked the T/A down.
Old Nov 18, 2013 | 12:55 PM
  #132
Staged07SS's Avatar
Administrator
Administrator
Took a "sick day" off work today....
Blower is off, coolant is drained, off with the head now.
Old Nov 18, 2013 | 02:02 PM
  #133
574's Avatar
574
Well done sir
Old Nov 18, 2013 | 03:23 PM
  #134
InfraRedline's Avatar
2 of the 4 "sick days" I've taken so far this year were for something car related The other 2 were real.
Old Nov 18, 2013 | 10:55 PM
  #135
Staged07SS's Avatar
Administrator
Administrator
lol, same here.
Well, all that's left to do is remove the upper radiator hose, un screw the tensioner, and drop the chain.
Had to cut the uninstall of the stock head sort today.... had to sign off on the wifes new car
The upper radiator hose looks like it's going to be a bitch to pull off the head.
It has never been removed, and is prob glued on like all the other coolant hoses on the car, haha.
I'm pleased to see the cams and valve springs in such mint condition. The whole valvetrain looked great!
Old Nov 18, 2013 | 11:23 PM
  #136
05RLS2's Avatar
Its not too bad, nothing like removing the glued on intercooler pump hoses
Old Nov 18, 2013 | 11:49 PM
  #137
ItalianJoe1's Avatar
The upper isn't actually glued. It can be on there pretty good though. I've never had one not come off though, with some persuasion.
Old Nov 19, 2013 | 06:54 AM
  #138
Tjolley's Avatar
lol, same here.
Channel locks will solve Ur radiator hose problem. Grab it and twist. Should come right off.
Old Nov 19, 2013 | 07:16 AM
  #139
Staged07SS's Avatar
Administrator
Administrator
Thank ya sir.
I didnt mess with it much. I tried a quick tug, and saw it didnt budge. Had other stuff I needed to do.
I'll be back at it this Wed.
Yes, those are terrible for sure.
Glad mine are all new/replaced.
Yeah, I didnt really mess with it. Thought it would come right off, lol.
Old Nov 19, 2013 | 10:03 AM
  #140
+1 on the channel locks and twist trick.
Old Nov 19, 2013 | 10:30 AM
  #141
574's Avatar
574
Old Nov 19, 2013 | 10:55 AM
  #142
off wiss zee head!!
Old Nov 19, 2013 | 10:59 AM
  #143
Staged07SS's Avatar
Administrator
Administrator
off wiss zee head!!
It will be off this Wed
I'm pulling the head out with the GMPP manifold attached (shorty style header ftw).... better eat my wheaties, lol.
These cars are so easy to take apart and build it's not even funny.
Old Nov 19, 2013 | 11:12 AM
  #144
nice. hey there's a how to on doing the timing set in the build book right? for my build im wanting to replace the whole set but if its too involved (which i'm sure it is) i may just replace the guide, chain and tensioner
Old Nov 19, 2013 | 11:15 AM
  #145
Staged07SS's Avatar
Administrator
Administrator
Yep, the build book has everything u need to time the motor. Just make sure to follow my cam how to for timing the cam postion sensor. The build book has that part wrong.
I'm replacing the guides and chain. I'm also using the arp (mrb) timing chain tensioner bolt set.
Old Nov 19, 2013 | 11:57 AM
  #146
Sox-Fan's Avatar
Got Brakes?
The yellow z06 got sold, so you need to finish this.
Thought you might want to know.
Old Nov 19, 2013 | 12:02 PM
  #147
thanks. eh i might just go your route man, i can't imagine all of the little gear being too worn out of shape. thanks
Old Nov 19, 2013 | 12:50 PM
  #148
Staged07SS's Avatar
Administrator
Administrator
Just inspect your cam sprockets, and the crank sprocket.
They should be fine, but it's still to good check.
My car has low miles, and the sprockets look new. I just want to get the chain and guides changed while I have her apart. Shouldnt have to touch the timing components for a while then.
Haha, thanks buddy
Old Nov 19, 2013 | 01:05 PM
  #149
Bluelightning's Avatar
Got Bewst?
Typically if you change a chain, you should change the sprockets too. Everything breaks in and wears to mate properly with each other. Change all or none IMO.
Old Nov 19, 2013 | 01:27 PM
  #150
Staged07SS's Avatar
Administrator
Administrator
You are actually correct about this, but the chain is sold separately as well....
If the sprockets look good upon inspection, than it should be fine to just replace the chain. On a higher mileage engine, it's def good to replace everything for sure.
I'm still up in the air about touching my timing chain. The plastic guide is on it's way to my house though.
I will see where I stand with funds once I get building. Just picked up a new car for the wife. I'm not cheaping out, but I have some other things that need to be taken care of being a married man now, lol.
