GM Stage 2 Pulley sizes
When i bought my car it already had the GM stage 2 installed and i assume that the pulley is the GM 3.0. I was reading on Cobalt Addiction that that pulley could be replaced with a 2.8 pulley and it would run fine. Is this true? will it mess up anything in the ECU?
GM stage two pulley is 3.065 inches, stage three is 2.99. Dont run a 2.8 pulley on the stage 2 tune.
You need 60 lb injectors and a retune. I would suggest OTTP's stage 2 kit
http://www.ottperformance.com/store/...-2-Kit-4p6.htm
but apparently alot of people have done it before and it works fine. I read that it was supposed to bring you into the right AFR because the GM stage 2 runs rich as it is.
