GM stage 3 question
Old Feb 1, 2012 | 12:50 AM
goeckeritz123's Avatar
GM stage 3 question
im on gm stage 3 though trifecta. im making 14 psi WOT, not sure but i think i should be a bit higher. could my BBV be bad? if so does anyone have one for sale?
Old Feb 1, 2012 | 01:23 AM
scoobydoobie's Avatar
Do the boost bypass mod and see what you make then. If the mods in your sig are accurate you should be making way more. I get 16.5 with my bypass hooked up and I've seen over 18 when bypassed.
Old Feb 1, 2012 | 01:24 AM
Blowncavy's Avatar
By doing this bypass mod what does that do? Is it good for car by doing so?
Old Feb 1, 2012 | 07:23 AM
I think it should mainly be used as a means to troubleshoot his problem. Some people run it like that all the time. It doesn't allow the boost bypass too open eliminating it from the list of possible issues.
Back in the day it was a popular mod to get over the built in limitations.
I'm not sure if anyone is still doing this.
Old Feb 1, 2012 | 07:27 AM
Staged07SS's Avatar
Administrator
Administrator
There is no set level of boost for the GMS3 setup.
Things like elevation, climate, airflow modifications, can all alter boost readings.
What setup did you have before your GMS3 tune, and what were your boost readings?
Note: I see you have a pretty free flowing exhaust. Did you ever check your boost levels before your exhaust modifications?
Old Feb 2, 2012 | 08:35 PM
I was 13 psi I think before catless dp. But I think either elevation or my bbv is my problem
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
