H/E in series vs. replacement
Old Dec 10, 2008 | 03:36 PM
Otown07's Avatar
Can anyone give any insight on running an aftermarket H/E in series with the stock unit vs. yanking the stocker and just running the aftermarket? I can't see why leaving the factory one in can hurt, but people probably wouldn't do it for no reason. Any answers?
Old Dec 10, 2008 | 03:42 PM
ShortStack's Avatar
Id personally run both, that way you have more coolant in the system.
Old Dec 10, 2008 | 03:58 PM
fzn14's Avatar
^thats my furture plan..not harm no foul with more coolent...But the pump has to keep up so that would be the only issue i can see
Old Dec 10, 2008 | 04:04 PM
light'bolt's Avatar
I think the pump will flow the same flow rate whether its pumping 1 gallon or 20.......
but I could be wrong..
Old Dec 10, 2008 | 04:05 PM
ShortStack's Avatar
Your right.. the only problem with the coolant pump is that it stops working...
Its actually a strong pump.
Old Dec 10, 2008 | 06:08 PM
lsjwannabe's Avatar
Each has there pro's and cons
With both h/e inline there is obviously more fluid in the system and it takes longer to heat.
Although once you do heat up you are sucking in some of those engine temps due to the location of the stock unit.
With one front mounted there is not as much fluid in the system but the increased surface area for contact cooling is much better, and the stock unit being gone is not going to soak up the operating temps of the engine bay.
I personally ran both and option b and loved it.
Hope this helps point you in the right direction
Old Dec 10, 2008 | 08:34 PM
SSdan's Avatar
I killed the stock one and just run a ZZP front mount. Personally like it better because the fluid cools down quicker then if I ran them in series.
Old Dec 10, 2008 | 08:49 PM
flash13brandon's Avatar
I run just the CXR one because I personally thought the way LSJWannabe said about the two stock ones and thought that it might lose pressure?
Old Dec 10, 2008 | 09:18 PM
lsjwannabe's Avatar
Not really you would be surprised how well the stock pump actually works in those situations.
Old Dec 10, 2008 | 09:25 PM
drew1991sf's Avatar
how long do they take to install? and wat should i expect from it?
i just ordered one today
Old Dec 10, 2008 | 09:30 PM
lsjwannabe's Avatar
The install is around 1 hr if you have access to the proper tools not tough at all. Do you have the install instrudtions?
Old Dec 10, 2008 | 09:46 PM
Hmm..didnt realize how good the pump was...what causes it to fail??
Old Dec 10, 2008 | 09:49 PM
lsjwannabe's Avatar
The system not bleeding itself properly, most people run with air in the system and it can cause it to fail easily.
Old Dec 10, 2008 | 09:56 PM
Sharkey's Avatar
according to the info i found on a cobra/lightning forum, the pump fails because the brushes are soft and wear out. the pump is better for use in an application were its not on all the time. its also only rated for around 1000 hours of use.
Old Dec 10, 2008 | 10:10 PM
drew1991sf's Avatar
so if im just gonna leave the car as is should i leave the existing h/e?
and where do i get the instructions cuz im having some1 else do it for me
Old Dec 10, 2008 | 10:13 PM
lsjwannabe's Avatar
http://www.ottperformance.com/instru...structions.pdf
there ya go.
You could go wither way really its up to you, take my advice for what its worth either way will work good
link_630's Avatar
what if you put in an inline pump that could handle the heat of the coolant to help out the stock pump and have ease of mind?
Old Dec 10, 2008 | 10:16 PM
drew1991sf's Avatar
do instructions come in the box?
Old Dec 10, 2008 | 10:31 PM
lsjwannabe's Avatar
No they do not i believe print these out
Wasted money imo, they are doing the same job
Last edited by lsjwannabe; Dec 10, 2008 at 10:31 PM. Reason: Automerged Doublepost
Old Dec 11, 2008 | 01:06 PM
rnjmur's Avatar
Well, technically you could but it would be a little more complicated than just thowing in an inline pump. You would have to have two seperate outlets (one for each pump) then you would have to combine them somewhere. With a dual pass endplate you could run one pump to each inlet on the dual pass and the two flows would combine in the intercooler.
The IC and H/E system is closed with a single flow. If you just add an inline pump you can cause other problems. If the two pumps don't have the same flow rates you will end up hindering the flow instead of helping, not to mention one of the pumps will be working harder trying to flow faster than the other pump causing a back up of fluid between the two pumps.
Old Dec 11, 2008 | 01:16 PM
ShortStack's Avatar
There is still no need to replace the pump unless its broke.
Old Dec 16, 2008 | 05:18 PM
drew1991sf's Avatar
i need the instruction for the h/e install the adobe file wont open help some1!!!!!!
Old Dec 17, 2008 | 03:05 PM
ShortStack's Avatar
download acrobat reader from adobe.com
Old Dec 17, 2008 | 05:48 PM
restonSS's Avatar
I have the stock h/e out and a front mount. it works great to me
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
