Harrop blower swap peripherals
Old Feb 18, 2008 | 07:14 PM
  #51
shabodah's Avatar
Originally Posted by UmeNNis
I was browsing that site but didn't see where you can get more info on the gm racing ported lsj head?
You have to email them. I posted the info on another thread.
Old Feb 18, 2008 | 07:22 PM
  #52
jgarciarivera's Avatar
Originally Posted by 2K5SS/SC?
Personal thoughts on minimum requirements to run the 2.75" pulley:
60lb injectors
HPTuners or a tune
Headgasket and headstuds
Full exhaust w/ (min) 2.5" pipe
Intake
Dual Pass Mod/Heat Exchanger
Good Clutch
Wideband to monitor
As Witt said, it all depends on pulley size. From the list of 2k5ss/sc IMO, I'll say these are basic:
60lb injectors (I need a wiring harness for my 60's)
HPTuners or a tune (don't have it)
Full exhaust w/ (min) 2.5" pipe (GMPP installed)
Intake (Already have a fujita)
Dual Pass Mod/Heat Exchanger (2nd h/e i will buy it from ebay)
Good Clutch (I have a stage 3 exedy on schedule for installation)
Wideband to monitor (don't have it)
fuel pump (just to be sure the IDC's don't go crazy) (already have return-style fuel system capable of 500HP)
Old Feb 18, 2008 | 07:38 PM
  #53
firestorm's Avatar
buy a blower, and put it on a new camaro.
Old Feb 18, 2008 | 09:14 PM
  #54
TVS_SS's Avatar
R1320 is not big enough for the new camaro
Old Feb 18, 2008 | 11:17 PM
  #55
UmeNNis's Avatar
link?
Old Mar 4, 2008 | 10:36 AM
  #56
Pully Police's Avatar
While most people are looking at running this blower at the ragged edge with the smallest pulley possible - I would go a different route.
Basically, I would get cooling mods (Meth, dual pass, larger heat exchanger, colder plugs), open up the exhaust a bit (2.5 inch), get a CAI (eg. Rebel 3" intake), 60lb injectors, and run the blower so it will mimic the M62 with a 2.8 on it. This way, you dont have to pull your motor and dump 7k into rebuilding the entire thing to handle stupid amounts of power. The result *should* be a cooler intake charge at lower blower speeds and less drag on the engine. this would both creat HP from the clloer charge, which would allow more tuning "headspace" and free up HP due to less drag induced on the engine. The lower blower speeds would also contribute to longer blower life. Crap...I dont need any more than 300whp - for the type of driving I do, 275 would be perfect. I would rather get 275 from a "slow" spinning, cool, durable TVS, than 275 from a hot, overspun, power sapping, M-62.
If this blower performs up to the hype, I should not have to worry about pistons and sleeves at all with 275WHP.
Make sense??
Old Mar 4, 2008 | 10:42 AM
  #57
Raven SS's Avatar
Make sense??
good point...for those thinking there going to buy this thing and slap on a 2.8 pulley onto it and be fine with a stock engine are gonna have some bad news coming to them...u thought crankwalk was bad in the DSM's wait til ur crankshaft blows out the block thru ur oil pan...Harrop has stated that this blower wont damage ur engine..it will DESTROY it if u dont take the proper steps in prepairing it
Old Mar 4, 2008 | 11:04 AM
  #58
Plus - if you then decided to pull the engine and do some crazy stuff, you just have to get a smaller pulley and tune.
If I get this blower, I will not be looking to make any more than 300WHP (tops) with it. this blower could open up HP that the inefficiencies of the current design eats up. In a nutshell, I want to run the same HP that a 2.8 - 2.6 pullied LSJ runs - but with a more efficient, slower spinning blower AND all the cooling mods, meth, fuel, etc. I think that my internals would be very safe and I would not have to worry about reliability as blower is not tossing a bunch of hot air in the intake. I could have more freedom to run more timing, more headroom with my AF ratios, etc.
I dunno...I dont need more than 300WHP - its all just for bragging after that...and I already have a huge member and a hot wife who loves it :P
Old Mar 4, 2008 | 11:05 AM
  #59
Raven SS's Avatar
im shooting for 450+ just to shut turbo guys up..my driveable hp is going to be under 400 for sure tho
Old Mar 4, 2008 | 11:19 AM
  #60
Well...if my 300WHP car can't shut them up - a slap across the face with my johnson will leave them speachless
(Sorry...I could not resist..)
Old Mar 4, 2008 | 11:22 AM
  #61
Raven SS's Avatar
lol...im building mine to kick the **** out of corvettes
Old Mar 4, 2008 | 11:43 AM
  #62
Area47's Avatar
Rent me! per hour
you can get 275 easy from the m62. why spend money in area's you don't need to.
Old Mar 4, 2008 | 12:35 PM
  #63
You are correct - and I hear what you are saying. But I am looking to make a relaible 275 - 300 WHP. I figure that I can do it (275) on the M62 for a little while, but when I have the extra funds, I will get the TVS (If it lives up to the hype) and swap it out - not to make BIG power - but to make the power that I want, more efficiently. I know it seems a bit cost prohibitive, but I want reliable, efficient power - and I DONT want a turbo...before you even mention it
Area47, I am a good tuner, but you have alot more experience with the software and quirks of these cars than I do, but I dont want to have to bandaid the tuning due to the fact that I am running the M62 out of it's efficiency range.
Oh yeah...I am **** retentive <-- that may explain alot too
Old Mar 4, 2008 | 12:43 PM
  #64
Area47's Avatar
Rent me! per hour
with the lsj tables. you don't have much of a choice but to bandaid it. you have to change one table to get it to work in another, blah blah blah.
to get 300 to the tire. you don't need a small pulley to do it, just have to look in another area's to get the power from, and then spend the money to do it.
i won't disclose how much i have spent on parts to get to 300 whp without a 2.5 pulley. i will say it is enough to hit 370+ with a turbo kit
blargh
Old Mar 4, 2008 | 01:59 PM
  #65
shabodah's Avatar
IMHO, the fuel system is what is causing so many tables to be "bandaided" in the first place. Just a proper fuel system on its own will help with a lot of these issues.
Old Mar 7, 2008 | 07:32 PM
  #66
Smarty Art's Avatar
I believe the intake manifold is going to be the biggest restriction. I remember some company was going to offer to port them but no one seemed interested.
Old Mar 7, 2008 | 07:34 PM
  #67
Omega_5's Avatar
DIY coming soon....
Old Mar 7, 2008 | 08:22 PM
  #68
RL-2005's Avatar
has everyone forgotten the kenne bell boost-a-pump?!?!??!
Old Mar 7, 2008 | 08:30 PM
  #69
USMCFieldMP's Avatar
Rattlesnake Race Shop
Subscribed for later readings.
Originally Posted by Omega_5
DIY coming soon....
Thank God.
Last edited by USMCFieldMP; Mar 7, 2008 at 08:30 PM. Reason: Automerged Doublepost
Old Mar 7, 2008 | 08:35 PM
  #70
Dead EyeZ24's Avatar
subscribed
Old Mar 7, 2008 | 08:41 PM
  #71
BRN169's Avatar
Thought I subscribed but guess I missed it... Haha, got it this time!
Old Mar 7, 2008 | 11:23 PM
  #72
shabodah's Avatar
The boost-a-pump is good for short term and moderate improvement over the stock system. It's a basically a bandaid that stretched out the capabilities, and does not have any proper fix for the improper way fuel is being metered.
Old Mar 11, 2008 | 04:57 PM
  #73
RL-2005's Avatar
is there any type of fuel pump duty cycle parameters in hptuners? the turbo focus guys have messed with some of these settings and had some success when used in conjunction with a voltage amplifier. i agree the BAP alone wont help much
Old Mar 11, 2008 | 05:00 PM
  #74
Area47's Avatar
Rent me! per hour
if there was. we as a collective mind would have found it.
Old Mar 11, 2008 | 05:16 PM
  #75
95cam86roc's Avatar
subscribed....
ThoR294
Oct 4, 2015 08:44 PM
jimbofug007
Oct 2, 2015 12:06 PM
ThoR294
Sep 28, 2015 05:31 PM
goaliemo
Sep 28, 2015 01:37 PM
