Having an issue with a couple CEL's (P2122 & P2138)
Well, I seem to be having a problem with 2 CEL's. The car didn't start acting up for a month or two after we put the new engine in. The first code I'm getting is a P2122 and that seems to be the code that pops up the most. The other is a P2138. Very rarely will both of the codes pop at the same time. it's mostly the 2122. Sometimes it will be the 2138. I know it has something to do with the APP sensors. i tried switching out the pedal for a new one, also unplugged all electrical connections and cleaned them with electronic parts cleaner. doesn't look like there are any breaks in any wiring or anything. Is there anything else i can do?
well squints.. this is what this guy did... He is a member on other forum and posted on the other site and not here
http://www.*******************/forum...2122-amp-P2138)
sorry to bring this back from the dead but no, im still having this problem. it is intermittent unfortunately. im wondering if it may be wiring related because i just threw a P2138 driving home normally. hit a bump, and it threw the car into limp mode. i have 2 TB's and both of them still throw the codes. pretty aggravating because thats the only CEL's that have come on. i would love to diagnose this myself but i have no tools and honestly wouldnt know where to start >.>
ya know it helps if you post what the codes are helps alot this list is located in the correct section for this post problems /service
https://www.cobaltss.net/forums/prob...-merged-12015/
a list for all of the codes
Problems/Service/Maintenance - Cobalt SS Network
P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage -PCM
P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation -PCM
hey dingleberry you posted numbers to a code without the definition as to what they mean next time don't be lazy post the code number and definition and they can be found here as were your post should be also
I was throwing the same codes replaced everything with no solution to the codes. It turned out to be the fuel pump. Turn your key on and then wait a few seconds. Then take the fuel rail cover off and test for fuel pressure. If you don't have any then your fuel pump is the issue.
It was barely connected. every bump or hard acceleration would cause it to damn near stall out when I finally made it home that morning I couldn't get it to turn over again. Replaced all the parts: tb, maf, app sensor nothing worked. So finally checked the fuel rail and low and behold I had no pressure whatsoever dropped the tank went to unplug it and it was barely on pushed it in all the way went into the car and turned it over and bam started right up no problem no codes idled fine. Pissed me off so much I turned the car off and went back inside for about 2 hours to calm down then came back out and put the tank back on
