head studs/gasket replacement
Old Oct 10, 2009 | 06:44 PM
06cobalt_ss's Avatar
Ok my mech jus got back to me. I shifted my head gasket. He suggests upgradin the head gasket and head studs. So which are the best headstuds as well as the best headgasket. Please give me a part # for the product. My mech will be orderin the parts so he just needs a name and part number. Thanks guys
Old Oct 10, 2009 | 07:01 PM
SCcobaltSS's Avatar
ARP or golden eagle for the studs and Cometic for the gasket
Old Oct 10, 2009 | 07:02 PM
SloBaLt RiDeR's Avatar
x2..^^
Old Oct 10, 2009 | 07:17 PM
jbenso4's Avatar
x3 /thread
Old Oct 10, 2009 | 07:37 PM
I heard the cometic gasket sucks n a lot of ppl have problems with it. I need part numbers where can I get the part # for these parts
Old Oct 10, 2009 | 07:51 PM
ShortStack's Avatar
the cometics have been having some problems lately...
OTTperformance has everything.
Old Oct 10, 2009 | 08:09 PM
qwikredline's Avatar
I am thinking that oem or arp it dont matter same goes for the gasket. seems to me you need to find the root cause for the head lifting, coz if u dont, its:" gonnahappenagain.com"
Old Oct 11, 2009 | 04:17 AM
2K5SS/SC?'s Avatar
The main problem people are having with Cometic headgasket is improper preparation. Get your head resurfaced, scotchbrite the deck, and ensure it is all clean with brake cleaner. Then follow the headstuds instructions for install. Easy day.
Cometic headgasket and ARP or Golden Eagle headstuds.
Old Oct 11, 2009 | 02:58 PM
Tennpenn83's Avatar
the reason for the cometic headgaskets failing has nothing to do with the quality of the headgasket.
this ^
oh, and not torquing the head down correctly or tight enough
Old Oct 11, 2009 | 06:19 PM
hungryhip-ccp's Avatar
hmmm cuz i did all that and my cometic still blew... so, it a guessing game at this point...
although i do like the coolant passages on the cometic more than oem
Old Oct 11, 2009 | 06:58 PM
Tennpenn83's Avatar
pics of said failure? the headgasket is multi-layer steel, just like the stocker. even when i had headstuds that stretched on the stock motor, the headgasket still held
Old Oct 11, 2009 | 08:21 PM
likw i said its a guessing game... im not gonna sit hear and say anything about either because my block was'nt decked... so that could been the reason.
motor was i perfect running cond had 12,000 mi when i pulled the head to put in pistons didnt think i needed the block resurfaced, just the head, but it held for 1.5yr before i turned up the boost and it blew on 23-24psi and approx 400whp... held fine at 18psi and 370whp.
some are having luck with them some arent, i wish i could see more applications being pushed with the stock HG, so i know what to expect from it.
Old Oct 12, 2009 | 11:00 AM
SCcobaltSS's Avatar
I thought 06blackg85ss had this on his 500+ HP car and it held even when his block grenaded?
Old Oct 12, 2009 | 07:32 PM
Tennpenn83's Avatar
yeah, i would always recommend re-decking the block and then, like you said, roughing it up with a scotch-bright before putting the new gasket on. would that have prevented your mishap...? idk, but even though i recommend doing that, i didn't do mine when i installed my pistons in may. i didn't have the time/money at that time, and I was going to do a p&p head in july. never got around to it, but i am still running on the cometic with 20+psi on a tvs with no issues
i believe you're right..
Old Oct 12, 2009 | 08:18 PM
Tennpenn is right (again)No substitute for following correct procedures....when I was a kid i put my motor together with so much dirt it blew up right away. I even lined up the ring gaps carefully so they were in line (doh) so thats how you learn I guess....if the block is straight cleaning it up is essential like you said, but if you tune it wrong, or lose an i/c pump or fuel pressure and / or get runaway detonation it will blow up no matter what gasket you have on it ....
ineedacobaltss
Nov 7, 2015 02:25 PM
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
Sep 28, 2015 12:51 PM
