Help- Cranking Issue
Old Feb 13, 2010 | 04:44 PM
S.Cobalt.S's Avatar
Unhappy Help- Cranking Issue
Alright, So my car does this crazy **** time and time again, Where I'll go to crank it and it just turns over, and turns over. (Granted, It doesnt do this every time I get in my car, but maybe once or twice outta ten times). But when it does do it, its a pain in the ass, It usually takes three times at the least to get it to finally fire. But today, It physically took 10 times of turning the car over before it crunk.
Any Ideas?
Thanks
Old Feb 13, 2010 | 06:47 PM
qwikredline's Avatar
when did you put in new sparkplugs last? Sounds like a long time ago....for a 2.5 pulley car and meth
Old Feb 13, 2010 | 07:02 PM
S.Cobalt.S's Avatar
Well, I my plugs have 14K miles on them. I've actually pulled them out within the last month just to check, and see if I should buy new ones. But they looked immaculate. Still looked brand new, the tips weren't all burnt or anything.
But I may just buy some new ones anyways to try it. Its just strange how random these cranking issues occur.
Old Feb 13, 2010 | 07:10 PM
you got spark air fuel and compression it will run. the computer is cranking the motor and its not running. so check those one of them is stopping it from starting...
Old Feb 13, 2010 | 07:15 PM
sherm420's Avatar
this happened to me when i had a major gas leak on my 2006 sc ...check ur tank asap
Old Feb 13, 2010 | 07:19 PM
S.Cobalt.S's Avatar
Alright, Will def..check those. Its almost like my injectors are clogged and its not spitting enough fuel out to crank. But once it does crank, everything's fine, car runs like a champ.
Old Feb 13, 2010 | 07:32 PM
sherm420's Avatar
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/taking-forever-start-104236/
https://www.cobaltss.net/forums/parts-66/need-fuel-pump-assembly-105286/
my two threads on this topic
Old Mar 3, 2010 | 09:00 PM
S.Cobalt.S's Avatar
Alright, Well It did it again really bad yesterday morning, it just turned over and over for like 15 minutes. While is was turning over, sometimes it would make the squeeling noise (like when you try to crank a car when its already running), So I finally got it running, and it was spittin and sputtering kinda, so i took off up the road, and check engine light comes on, car felt weak...so i pulled over, let it sit for a minute then,....fired right up, ran like a champ for the rest of the day....CEL was coming off and on, but after I restarted the car, I havent seen it since?????
Old Mar 19, 2010 | 03:36 PM
S.Cobalt.S's Avatar
Car will not crank...Period
Old Mar 19, 2010 | 03:42 PM
koch1ar's Avatar
ahh u should have read the code
Old Mar 19, 2010 | 03:43 PM
Illini_06SS's Avatar
what was the CEL code that popped before?
Does it smell rich once it starts running?
If it smells rich, it's a spark issue. If it doesn't, I'm guessing it's a fuel issue.
Old Mar 19, 2010 | 08:29 PM
S.Cobalt.S's Avatar
Alright, well finally got the car to run, CEL was still on so I drove straight to Advance...Guy said it was showing 6 codes, but 3 were repeats...Here they are..
P0335
P0141
P0036
Old Mar 19, 2010 | 11:10 PM
ThiZo_19's Avatar
id say crank or cam sensor either or...plug it to a obd2 scanner perferably a tech 2 and see if u have an rpm reading when cranking...
Old Mar 20, 2010 | 03:25 PM
S.Cobalt.S's Avatar
Any more suggestions?
Old Mar 20, 2010 | 06:27 PM
P0335 - Crankshaft Position Sensor A Circuit Malfunction
P0141 - Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0036 - HO2S Heater Control Circuit (Bank 1 Sensor 2)
So it's your crank position sensor and your downstream O2 sensor that are throwing codes.
Old Mar 20, 2010 | 10:58 PM
Coblasts's Avatar
Possible loose emiss fuse under the hood or bad wiring or connector.
check the fuse is seated properly first.
Old Mar 21, 2010 | 02:14 AM
S.Cobalt.S's Avatar
The oxygen sensor is temp disconnected. Header install was great but the O2 Sensor wires were just a hair short. So I can understand that.
How difficult is the swapping of Cranshaft Position Sensors?
Old Mar 21, 2010 | 03:03 PM
ThiZo_19's Avatar
o2 sensors are throwing a code cuz ur crankshaft sensor timing could be a bit off and mixture could be off alitle. when driving to this place did u experience any misfires/hesitation? id change the ckp sensor b4 anything else and see from there. Goodluck my man
obviously inspect wiring b4 swapping parts...i usually jsut swap parts cuz I do it for a living and well to be quite honest...i dont pay when im wrong customers do :P lol
Old Mar 21, 2010 | 10:05 PM
S.Cobalt.S's Avatar
haha, I hear ya, I mean I'm pretty mechanically inclined, and actually race 4 cyl mustangs. But all these new high computer-ized cars now days. But like i said, the O2 sensor behind my cat is Not hooked up at all, it was too short to reach back to the plug. So i just left it unhooked, and i drove the car for like three weeks after the header install and never threw a CEL. But this cranking **** has been an off on thing for the last few months. The last time that the car did this, it was real jerky, weak, misfiring, putting along. This time when the light was on, it just drove the same, maybe lack of power, but didnt feel all that bad.
Old Mar 21, 2010 | 11:17 PM
ThiZo_19's Avatar
swap the sensor man. **** yeah ur o2 is disconected that would obviously explain the codes for malfunction! lollll im retarted sometimes
Old Apr 5, 2010 | 07:33 AM
S.Cobalt.S's Avatar
So, I've ordered the sensor about a week ago, Still hasn't arrived, but now my car like won't crank the first time, but fires up the second time with this crazy ass idle, and then i can physically turn the key off and be standing outside of my car and it will still be running? WTF
Old Apr 6, 2010 | 08:47 PM
S.Cobalt.S's Avatar
TTT, Any Ideas?
Stuff
Oct 1, 2015 05:47 PM
Tupp
Sep 30, 2015 08:18 PM
cw383
Sep 30, 2015 12:41 AM
roth
Sep 26, 2015 12:16 PM
