Help For The New GM Spec 2.8 pulley!
Old Jun 15, 2006 | 09:43 AM
CTCOBALTSSS's Avatar
Post Here's Help For The New GM Spec 2.8 pulley!
Now that the new GM Spec 2.8" pulley is out, there are going to be alot of questions. So I wanted to make a thread that will answer all the questions. Please add questions and answers if I missed something.
Questions....
1. Are 42lb/hr fuel injectors enough for a 2.8" pulley?
2. Do I need a new belt?
3. Do I use 1 step or 2 step colder plugs?
4. Where do I get 1 and 2 step colder plugs?
5. What is the best gap for the plugs?
6. How easy is the pulley swap?
7. Will it void my warranty?
8. Where can I get the GM Spec 2.8" pulley?
9. Can I purchase a GM Stage 2 hub by itself?
10. How much boost does the 2.8 pulley produce?
11. How much HP will I gain?
12. How close is the 2.8" pulley to the supercharger's redline?
13. Where can I buy the GM Stage 2 belt?
14. Do I need to reset the PCM and how?
Answers....
1. Yes, the 42.5lb/hr will be just fine.
2. No the GM stage 2 belt will work just fine.
3. I hear 1 step colder is fine, copper plugs.
4. One step colder plugs http://www.ngk.com/results_cross.asp...kr7e&x=33&y=13
Two steps colder plugs http://sparkplugs.com/results_cross.asp?pid=lfr7a-ix
5. Between .35 and .40 .35 is your best bet IMO!
6. Remove 4 pulley bolts, remove belt, remove pulley, put new pulley on, put the belt back on, tighten bolts on the pulley, done. Very easy!
7. Well I don't think GM techs will know the difference. Technically speaking, yes.
8. Right here http://www.pulleyboys.com/lsj28.html
9. Not yet!
10. About 17.5psi.
11. Approximately 15-18hp.
12. Our supercharger's redline is 16,000rpm. A 2.7" pulley is 15,555rpm. You're safe!
13. Here! Direct Link http://www.crateenginedepot.com/stor...3-P1592C0.aspx
14. Yes. Unplug your negative battery cable for approximately 3 minutes. Hook it back up. All set!
*Link to the GM Spec 2.8" Pulley Information Thread --> https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/gm-stage-2-2-8-pulley-ready-sale-22950/
*Link to the GM Spec 2.8" Pulley Discussion Thread --> https://www.cobaltss.net/forums//showthread.php?t=23252
Old Jun 15, 2006 | 09:59 AM
cavy-to-SS's Avatar
very nice write up....i know so much now
Old Jun 15, 2006 | 11:10 AM
max_boost's Avatar
I think 2steps colder is to cold of a plug. Intense is only using one step colder with their Stage 5 kit which runs a 2.5" pulley. Also, there is going to be more knock with the Iridium plugs, I'd stick with copper.
Old Jun 15, 2006 | 11:15 AM
silverSS's Avatar
agreed
Old Jun 15, 2006 | 11:21 AM
Rusty's Avatar
yea, i have a 2.85" pulley with 1 step colder plugs (7 instead of 6) and it runs fine. i have only minor slippage with stock belt and tensioner. stage 2 belt should be perfect. i'm also assuming the reflash will be fine to run with that pulley.
Old Jun 15, 2006 | 11:25 AM
That's why I wrote, "I hear 2 steps colder". Thanks.
Edit!
Old Jun 15, 2006 | 11:41 AM
Thanks bro!
Old Jun 15, 2006 | 01:29 PM
Bump for the lunchtime crowd!
Old Jun 15, 2006 | 02:40 PM
SStud's Avatar
Why not go two steps colder. I meen you can't really say "Because Intense says so" There are other companys out there that recomend 2 steps cooler. So i meen you can't really rule the two steps cooler out of the picture. Also, are you really going to stay at this pulley size? Probably not...So why not go two steps cooler and not have to worry about KR in the short run. Also, when it comes to engine managment are you going to go with something thats "just fine" or are you going to go with something that works best.
I'm not trying to get on anybody's bad side i'm just trying to keep the options open for people who are willing to check it out. So take it for what it's worth and for the people who want to try out the Two Steps Colder plugs (Like myself) Post up your experiences asap after you get the pulley installed so others can benefit also.
Old Jun 15, 2006 | 02:47 PM
OniMirage's Avatar
you go colder when adding lots of boost because of the heat the plugs will be exposed to. When your engine runs as a daily driver those extreme heat levels are rarely if ever felt so it could be too cold going two steps. If your running like a maniac around a track having 2 steps colder would be better.
Old Jun 15, 2006 | 03:16 PM
ReMz's Avatar
nice write up. will be very helpful to a lot of members.
keep it up to date
Old Jun 15, 2006 | 03:17 PM
OniMirage's Avatar
I have a question ... since the dealer never gave me my bit back can I purchase another bit?????????
Old Jun 15, 2006 | 03:27 PM
keep it up to date
Thank you sir!
I don't know bro. Someone will chime in with the answer i'm sure.
Old Jun 15, 2006 | 03:36 PM
OniMirage's Avatar
well if someone knows the pull boyz im sure that they can make a cast out of a bit someone already owns then fab a new one then sell it as a replacement ... hell if they did that they would already have at least one customer
Old Jun 15, 2006 | 03:39 PM
Very true and that's a good call.
I updated the thread so it contains a link to 2 step colder plugs for the guys/girls that want them. They are not necessary though!
Old Jun 15, 2006 | 03:41 PM
p7x's Avatar
p7x
well done!
Old Jun 15, 2006 | 04:40 PM
Originally Posted by p7x
well done!
Thanks bro. I appreciate it.
Old Jun 15, 2006 | 04:51 PM
DTM2188's Avatar
Great post, answers a lot of questions. I got another one, though. About how much hp do you think we can gain by switching (approximatly). Thanks.
Old Jun 15, 2006 | 04:54 PM
Well for every .1 you take off the pulley size you should gain around 10hp.
Gm Stage 2 pulley is 3"
So a 2.8" pulley should yeild around 15-18hp realistically.
I will update the thread!
Old Jun 15, 2006 | 05:00 PM
SS_SC_Cobalt's Avatar
nice CT, Good idea fo sure!
Old Jun 15, 2006 | 05:52 PM
Matty's Avatar
Good write.
Hopefully all the info stays in this thread.
Old Jun 15, 2006 | 10:11 PM
Originally Posted by Matty
Good write.
I hope so too. That would be nice and convenient. Thank you BTW!
I updated the thread to include questions about supercharger redline.
Old Jun 16, 2006 | 09:53 AM
Thank you sir. It goes well with your thread. Yours gives all the info, mine answers all the questions. Only if everything was that smooth. I'm going to add a link to your thread. It can only help. Later bro...
BTW. I still need to see those lights in person.
Old Jun 16, 2006 | 09:57 AM
anytime....go to the poughkeepsie meet I'll go there and you can see em
Old Jun 16, 2006 | 09:59 AM
That's not too far away. When and where is it?
