Help! - Weird option B/Dual Pass symptoms
Old Jun 13, 2011 | 10:23 AM
Corey-04RL's Avatar
I got the zzp S3 H/E and dual pass installed this weekend. Everything is hooked up using ZZP's option B kit. I don't think everything is running smoothly and need some educated opinions. Here's what is going on:
I only had T Fittings, so there is extra tubing at the moment; I plan on redoing this with some molded tubing later on, but it is hooked up exactly like the ZZP diagram/crate engine depot diagram.
I turn the car on, and the coolant level in the surge tank rises. It looks like air is coming from the 3/4” hose into the tank. The bleed line has coolant in it to about the same level as in the tank. I turn the car off, and the coolant goes back to where it was. Air can be seen bleeding through the bleed line. I did have to refill the tank (because it dropped below the original point) a few times, about half a gallon total. Things seem stable now – coolant rises and falls, but does not get lower than it was.
My trip to work is approx 20 miles. My IAT2 after letting the engine warm up were 120. (IAT at 80) IAT rose to 86 over the drive, IAT2 rose to 136. About 3 miles away from work, I mashed the throttle to get the IAT2 up to 150ish and then went back to cruising. IAT2 cooled to 146 but did not drop any lower.
Thoughts??
Old Jun 13, 2011 | 10:36 AM
Staged07SS's Avatar
Administrator
Administrator
You have air trapped in the system.
Old Jun 13, 2011 | 10:39 AM
CobaltVenomSS's Avatar
or green gunk
Old Jun 13, 2011 | 10:47 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by CobaltVenomSS
or green gunk
Old Jun 13, 2011 | 10:51 AM
ItalianJoe1's Avatar
In for results. Local car is having the same issue.
Old Jun 13, 2011 | 10:56 AM
Corey-04RL's Avatar
or green gunk
green gunk...not sure if serious??
any good ideas on how to bleed the system more?
Old Jun 13, 2011 | 10:57 AM
07BoostedG5's Avatar
https://www.cobaltss.net/forums/2-0l...h-iat2-253408/
Old Jun 13, 2011 | 11:00 AM
Sylver01's Avatar
run your car and then take the surge tank cap off. should help with burping it
Old Jun 13, 2011 | 11:11 AM
Staged07SS's Avatar
Administrator
Administrator
To release the trapped air with the opt b. tank I have always found it useful to raise the tank up while the car is running. This will help release any air pockets, and get your cooling setup running properly.
Old Jun 13, 2011 | 01:03 PM
rivaladore's Avatar
X2 I had to raise my tank high in the air before the system would start to purge air. Hold it up for a minute then put it back down and it should now purge on it's own
Old Jun 13, 2011 | 01:26 PM
Staged07SS's Avatar
Administrator
Administrator
Yep. Opt B can be tricky, but once you "jump start" the bleeding process, it works great!!
Old Jun 13, 2011 | 01:42 PM
Owen S's Avatar
off topic here, but thanks for all the great posts staged07. I'm just scrolling through the LSJ section and finding amazing info from you. Thanks!!
Old Jun 13, 2011 | 01:54 PM
Staged07SS's Avatar
Administrator
Administrator
No prob man. I'm here to help.
Old Jun 13, 2011 | 01:58 PM
staged is our own little cobalt scientist
Old Jun 13, 2011 | 02:00 PM
Sylver01's Avatar
All I did was run the car a bit. open the surge tank, run the car again on a little drive, open the surge tank again. I still depressurize the system every few days or so just to make sure it is bleeding. I have a little trickle of coolant coming in the bleeder line
Old Jun 13, 2011 | 02:17 PM
Staged07SS's Avatar
Administrator
Administrator
You can do it this way as well, but IMO it's much quicker and more efficient to just raise the tank up while the car idles. Either way works!
Last edited by Staged07SS; Jun 13, 2011 at 02:17 PM. Reason: Automerged Doublepost
Old Jun 13, 2011 | 02:22 PM
Corey-04RL's Avatar
Thanks for all the info! I did raise the tank up while the car was running and then kept it there with the car off. It seemed like it bled more after shutting the car off...So, I ran it, shut it off, and ran it again for about 45 minutes.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
importkiller
Sep 30, 2015 07:18 PM
goaliemo
Sep 28, 2015 01:37 PM
