How Hard is it to Convert to E 85?
Old Aug 23, 2011 | 08:01 PM
Omnigear's Avatar
pif corn have gotten more xpensive.... its more than regular gas >_<
Old Aug 23, 2011 | 10:20 PM
InfraRedline's Avatar
Originally Posted by ionRL_585
do you think its in my tune or something else causing the problem? its been around 80 and up and it gives me issues even then. its happend after like 4 weeks after i switched over to E but before then it would start up with no issues.
I would bet its in your tune.
And in most places E85 is about $1 less than premium or so, but there are places that raised the prices a lot lately. Here it is currently $2.99 a gallon for E85, $3.74 for 87, and I think $3.94 for 91.
Old Aug 23, 2011 | 10:35 PM
alleycat58's Avatar
Originally Posted by Sully20
Sweet! So basically just need 80's and an E-85 Tune, Thats Easy enough and correct me if I'm wrong but If I go E-85 with 80's Thiers pretty much no need for a Heat E/X or any Cooling MODS for that Matter if I go down to a 2.7 Right?
If you have a good tune, no, no need for cooling mods. E85 burns cooler than gas. I'm running mine on a 2.7 pulley on a TVS, just E for cooling, no meth no aftermarket h/e.
so if your on e85 u can only run on e85?
what kind of power increase / feul mileage do u get? roughly, i know, but come on work with me
You'll need to retune to run anything other than E85 on a regular basis. Like others said, you can limp home on 93, but you can't run it in boost or for an extended period of time.
Fuel efficiency will drop, mine went down about 12% from 93. Don't know about power, I didn't dyno before I went to E, but it made 345whp on E85.
2 questions:
how expensive is e85 compared to regular premium
and can you run premium if im in an area with no e85
Depends on your area. Here it's like 60 cents less than premium.
Old Aug 23, 2011 | 10:37 PM
Leafydialupking's Avatar
alley cat, add some more advance in your cruising cells.
Old Aug 23, 2011 | 10:41 PM
Omnigear's Avatar
the subsidy have ran out for corn so prices have gone up, specially here in socal
Old Aug 23, 2011 | 10:44 PM
alleycat58's Avatar
Not too worried about it. It may not be staying on E if the prices keep going up. Plus it's not available at the track, so it's probably going to go back to pump gas soon.
Old Aug 23, 2011 | 10:48 PM
Joemaster70's Avatar
how hard is it to have 110 octane? do you gotta tune for it or can you just put it in and drive?
Old Aug 23, 2011 | 10:49 PM
You dont have to change fueling just increase your spark advance to actually take advantage of the extra octane. Watch out with race gas though, around here all of ours is leaded and if you have a cat that'll clog it right up.
Old Aug 23, 2011 | 11:04 PM
Murdered SS's Avatar
just looked here in vegas for prices there the same as regular gas
Old Aug 23, 2011 | 11:36 PM
Omnigear's Avatar
for the ponies added its still worth it for me.
Old Aug 23, 2011 | 11:54 PM
  #36
I agree, now if every station wasnt over an hour away from me.
Old Aug 24, 2011 | 10:51 PM
  #37
TonyTuna's Avatar
Wuts up crew?
Ive been on E for about 2 months now, got my tune from zzp, even on warm days like today when its like 60 outside first thing in the morn I gotta warm my balt up, likes to lope till about 130-140* and I used to get 26-30mpg now with E its around 20-25mpg. I need to be properly tuned. Is there anyone that anybody knows of in the Bay Area?
Old Aug 25, 2011 | 04:01 AM
  #38
Redefined1's Avatar
Switching to e85 is easy as long as you have a good tuner around you.
Old Aug 25, 2011 | 04:14 AM
  #39
turbodSSboSS's Avatar
well i went on e for a short wile and loved the power but the pita of finding stations is no fun at al...
also like said up above if you live anywhere where it gets colder then 40* you will have big problems running e in the winter.
and i could be wrong but i thought e burns hoter then reg fuel? hence the more hp with a better and more solid burn? could be wrong but... i know with my ss/tc my cars normal temp went from 189* to 200*ish on e.
Old Aug 25, 2011 | 09:16 AM
  #40
E burns cooler and slower than regular gas, which lets you run more spark advance.
RaginChopsuey
Oct 27, 2015 01:27 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
