Injector issues
Injector issues
Ok, so after fixing the water issue with my car we notice a noise. start spraying things with carb cleaner and notice that where the injector goes into the motor on the far drivers side is leaking somehow. switched injectors around and sprayed again. same spot is leaking... so its not the injector. why would it be leaking and how would i get that taken care of?
Here is the thread from what happened to my car:
https://www.cobaltss.net/forums/general-cobalt-68/my-new-boat-%3D-kinda-73258/
also, has anyone had issues with the poly control arm bushings becomming kinda loose?
Last edited by chipmonk212121; Aug 25, 2007 at 08:14 PM. Reason: Automerged Doublepost
Sl0wbaltSS
Nov 21, 2018 11:11 PM
