Injector issues
Old Aug 25, 2007 | 08:14 PM
chipmonk212121's Avatar
Injector issues
Ok, so after fixing the water issue with my car we notice a noise. start spraying things with carb cleaner and notice that where the injector goes into the motor on the far drivers side is leaking somehow. switched injectors around and sprayed again. same spot is leaking... so its not the injector. why would it be leaking and how would i get that taken care of?
Here is the thread from what happened to my car:
https://www.cobaltss.net/forums/general-cobalt-68/my-new-boat-%3D-kinda-73258/
also, has anyone had issues with the poly control arm bushings becomming kinda loose?
Last edited by chipmonk212121; Aug 25, 2007 at 08:14 PM. Reason: Automerged Doublepost
Old Aug 25, 2007 | 08:29 PM
Shortbus's Avatar
Sounds like your injector clip isnt on all the way or may be broken.
Old Aug 26, 2007 | 12:03 AM
wrong side of the injector. its leaking where it goes into the head.
Old Aug 26, 2007 | 10:10 AM
bump....
anyone???
Old Aug 26, 2007 | 10:12 AM
Element2.4's Avatar
Did you make sure the little plastic piece that goes on the spraying side of the injector is there still?
Old Aug 26, 2007 | 10:16 AM
plastic piece? there is only an o-ring... on all of them
Old Aug 26, 2007 | 11:56 PM
Old Aug 28, 2007 | 12:17 AM
gonna take it to the dealership tomorrow to have em figure out whats wrong...... i hope its nothing big...
Old Aug 29, 2007 | 12:58 AM
...........survey says!!!!!!!!!!!!!
Cracked flywheel!
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
