Installing fender mount meth kit.. Why does it take so long?
Old Jan 15, 2009 | 10:52 PM
RedEcotecSS's Avatar
I've been reading on AIS website and it says for the trunk mount system it will take approx. 60-90 minutes to install. On the fender mount kit it says 2-3 hours. Why is this? Thanks.
Old Jan 15, 2009 | 10:55 PM
nikebaseballx00's Avatar
no idea but i usually dont listen to those times....
i took off my stock intake and put on an AEM in literally 30 minutes
Old Jan 15, 2009 | 11:01 PM
ShortStack's Avatar
You have to run a line from your trunk, to your engine bay...
Unless you run this line on the outside of your car, its gonna take a little while to drill some holes.
Old Jan 15, 2009 | 11:08 PM
Ummmm..
Reread first post...
Trunk mount takes longer then fender mount. I don't understand that..
Old Jan 15, 2009 | 11:09 PM
dvscobaltSS's Avatar
when i installed mine on my bumper i had to take the bumper off to get to the place i was mounting the pump. its a tight fit for the right placement for a drill if you have a front mount h/e. also running all the lines and getting everthing perfect did take about that long. i have a cool mist kit so wiering it up was different because i added a switch to be able to kill the power to the pump if i dont want to use it and also added an indicator light so i know when the pump is pumping
BLAZIN07SS's Avatar
I'm too JDM for you
i'm assuming they want you to remove the windshield wiper fluid container so you can tap the plug into it
Old Jan 15, 2009 | 11:10 PM
first post trunk 1-1 1/2 hrs fender 2-3 hrs
Old Jan 15, 2009 | 11:12 PM
Thats what I figured.
Old Jan 15, 2009 | 11:15 PM
ShortStack's Avatar
Dude are you kidding me?
The meth is mounted in your trunk.... so there for... you have to run a line from your trunk, to your engin bay...
im hoping you wanna hide this line... i was being sarcastic that you run the line on the outside of teh car (takes short amount of time)
To do it right and run about 10 feet of lines through your car will take a good couple hours...
Old Jan 15, 2009 | 11:18 PM
BLAZIN07SS's Avatar
I'm too JDM for you
dude did you read? lulz. he is wondering why it takes longer to install the fender mount kit when its all up front in the car while the trunk mount would take longer to run lines but it has a shorter install time.
Not according to AIS.
ShortStack's Avatar
Hes asking why it takes longer for hte installation on the trunk mount over the fender mount
Old Jan 15, 2009 | 11:19 PM
ShortStack's Avatar
Dude
Math > Me...
sorry... lol
No, I'm not. I'm asking why does it take a fender mount set up longer than a trunk mount.
Old Jan 15, 2009 | 11:28 PM
ShortStack's Avatar
Yea dude i realize that now im sorry.. lol
Im playing rock band 2 and totally was into it and just did this horrible math in my head.
i was seeing 20 - 30 min not 2-3 hours for some reason.
Last edited by ShortStack; Jan 15, 2009 at 11:28 PM. Reason: Automerged Doublepost
Old Jan 15, 2009 | 11:30 PM
Yeah, I'll give you that, it is kinda confusing. Haha.
Old Jan 15, 2009 | 11:34 PM
ShortStack's Avatar
I couldnt understand how it could be less time either lol..
Old Jan 16, 2009 | 02:59 AM
tdipowered's Avatar
why mount it in the fender?
Old Jan 16, 2009 | 03:08 AM
eurochevy's Avatar
o..m..g dude if ur gonna ask such a ******* questoin don't ask it at all..it doesn't go IN the fender
Old Jan 16, 2009 | 09:14 AM
rallycobalt06's Avatar
when i installed my AIS trunk mount (luckily i have a lift) it took me about 1.5 hours..... i really took my time and read the instruction a few times. i think it tastes longer for the fender mount because your using the windshield washer tank and you have to remove alot more. plus wiring could be alot different.
just buy my meth kit........... https://www.cobaltss.net/forums/parts-66/fs-lots-parts-stuff-150533/
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
