INTENSE Announces New Dyno Proven Stage Kits!
Old May 19, 2006 | 03:52 PM
  #101
Bad06SS's Avatar
Originally Posted by Rogue
7000
I would assume that all of the kits have a 7K rev limiter-due to the valve springs, correct?
Old May 19, 2006 | 03:55 PM
  #102
Rogue's Avatar
All of our stage kits will have a 7k redline, yes.
Old May 19, 2006 | 03:58 PM
  #103
ReMz's Avatar
Originally Posted by ReMz
hmm... how reliable/safe would any of these kits be at 7,000ft elevation.
... im guessing i would need a local custom tune
anyone feel like giving their input?
i kno that these tunes wont work right at high elevation.... ppl up here have problems with tunes all the time. so i'll rephrase, is it possible for me to put an intense kit on my car at this elevation?
Old May 19, 2006 | 04:39 PM
  #104
Bad GTP's Avatar
Here's a 100% stock car with our Stage 1 PCM. The red lines are stock and the blue lines are after the PCM flash.
Here's a link to the whole story:
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/235-whp-only-one-mod-20439/
Here's a Stage 3 kit on a stock car with no other mods. This time the red lines are with the injectors and pulley, and the blue lines are with the PCM flash too.
Here's a link to this story:
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/05-redline-pcm-tuning-results-20443/
Here's most of a Stage 5 kit on Rob Archer's car with exhaust work too. His blower is still stock though. The blue lines are with a GM Stage 2 flash, and the red lines are the tune Rob and I worked out together.
Here's a link to Rob's write-up:
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/i-never-thgought-id-see-20417/
Old May 19, 2006 | 04:43 PM
  #105
Gorilla unit 33's Avatar
nice .....
Old May 19, 2006 | 04:48 PM
  #106
Bad GTP's Avatar
hummm do you have a video of the car on the dyno or a video of the car on the street agains a nother car?? your number look great but it's only numbers on a sheet without proof...the so much dyno chart on internet without proof so i'm very septic...
Are you septic or did you mean skeptic? Please click on the links in my previous post. Some of the guys we dynoed took videos.
For those of you who don't know who we are, some of our 2005 bests include:
1. World's fastest FWD Grand Prix (9.64 @ 146 MPH)
2. World's fastest FWD Bonneville (10.71 @ 125 MPH)
3. World's fastest FWD Regal (11.51 @ 114 MPH)
4. World's fastest 2004 Impala (11.99 @ 113 MPH).
Here is a link to a thread about our team's 9.64 run. If you haven't seen it before, be sure to check out the video at the bottom of the first post:
3800 World Record Run - 9.649 @ 146.16 MPH!
Old May 19, 2006 | 04:53 PM
  #107
Bad GTP's Avatar
G.M. doesn't normally issue custom tunes for higher altitude. For example, if I want to drive my car up into the mountains, I don't need to go get my PCM reflashed at the dealership. Instead, my PCM detects the decreased barometric pressure and adjusts accordingly. All our PCM's come with a money-back offer good for seven days if you're not 100% satisfied, so feel free to give us a try.
  #108
black06ss's Avatar
i tried reading through to see if it was asked or answered and did not see it. i was wondering if you are the programs are actually tuning the computer or if they are tricking it?
Old May 19, 2006 | 04:54 PM
  #109
Bad GTP's Avatar
Yes, we use a combination of GM S.P.S., EASE and HP Tuners to reprogram PCM's.
Old May 19, 2006 | 04:59 PM
  #110
black06ss's Avatar
awesome thanks for the info.
Old May 19, 2006 | 07:52 PM
  #111
black06ss's Avatar
just tried calling 3 dealerships here to see if the would CASE my engine after the kit they all said "we wont touch it" if you can find some where that will good on you but for alot of people try calling some performance shops. just a heads up for some of you guys.
Old May 19, 2006 | 07:57 PM
  #112
JCswoosher2's Avatar
so will we be able to tweak the PCM more than what your comes with? would that require HPtuners then?
Old May 19, 2006 | 07:58 PM
  #113
BeermanSSSC's Avatar
Stage 5 Sold
  #114
Rogue's Avatar
Maybe try rewording it. Look I need the procedure for DTC P0315 done to my car and it takes about 5 minutes with a tech II. If I give you 20, 40 , 60 bucks will you do it for me? Sometimes a little social engineering is required.
Old May 19, 2006 | 08:57 PM
  #115
eastcoastz's Avatar
The last dyno of Robs flash compared to the GM Stage 2 flash, what pulley and injectors were used in that GM dyno run?
Old May 19, 2006 | 09:08 PM
  #116
dstinsman56's Avatar
will your guys pulleys fit on the zzp performance hub?
Old May 19, 2006 | 09:11 PM
  #117
selfinfliction's Avatar
quick question.... the cars stock put out 12.5psi...... so stage 1 is a reduction in boost?
Old May 19, 2006 | 09:18 PM
  #118
Highhp's Avatar
Yes, it will
Old May 19, 2006 | 09:26 PM
  #119
when i order the pcm where do i specify i want the stage 5 tune? also is the only way to talk to someone from intense on the phone to leave a message? i called all day today and can only leave a message.
Old May 19, 2006 | 10:08 PM
  #120
Rogue's Avatar
Sorry but we were incredibly swamped today and a lot of times we are out of the office working on cars, or packing shipments, or taking care of customers in the shop. If you leave a message we usually get back to you within a few hours. Email is usually answered the fastest. PM's are pretty hard to keep up with as we do visit a lot of forums.
Old May 19, 2006 | 10:12 PM
  #121
Bad GTP's Avatar
Yes and yes.
Same. Nothing was changed between those pulls except the PCM tune. Note: the numbers for all our dyno pulls that night were a little on the low side, due to the fact that the humidity was 95%.
Our Stage 1 kit includes a 3.30" pulley, which is almost identical to stock. So boost is the same as stock. We always try to list our numbers conseravtively. So we only publish 11 psi for two reasons. First, boost is lower at higher altitudes. And second, as you get to know us better you'll come to understand that we like to underpromise and overdeliver.
Old May 19, 2006 | 10:14 PM
  #122
im just trying to find out what the downtime will be cause im shipping my parts so i dont have to recalibrate pcm crank sensor. can you over night ship parts? also how do i get stage 5 tune specified in my order.
Old May 19, 2006 | 10:24 PM
  #123
a real honest question. If we r going to do more tuning. it would be best to just get HPtuners instead of your PCM. right? but if we r only going to do the stage kit u offer. it would be more fitting to get your PCM?
Old May 19, 2006 | 10:53 PM
  #124
EndZz's Avatar
How much for a stage 4 WITH a ported blower?
Old May 19, 2006 | 11:13 PM
  #125
stage 4 price = $689.99 + $299.99 to port blower($200 core charge)
