It's about that time
Old Jan 15, 2014 | 10:05 PM
  #51
mrbelvedere's Avatar
Originally Posted by WSbalts
My question is, with everything listed in the op would I be capable of running s1 or possibly s2 cams without blowing up?
if you don't know if cams will or will not hurt your engine you might be a *******
again go read about engines and modding it doesn't have to be about ecotecs all engines are the same in one big way
Old Jan 16, 2014 | 05:46 AM
  #52
WSbalts's Avatar
I was wondering because with the extended powerband that going stage cams give weather or not 60#s would flow enough fuel through to support revving to or past 7500. I'm under the impression that it wouldnt make a hugw difference provided its tuned well, but I wanted to double tap and make sure before I started getting parts together. Reasonable logic/question for someone with minimal experience.
And I'd just like to point out that if you don't have anything constructive to say, then get the **** out and quit running up your post count.
Old Jan 16, 2014 | 08:21 AM
  #53
I have given you use full advice your to blind to see it
Old Jan 16, 2014 | 09:06 AM
  #54
armcclure's Avatar
Dual pass or better yet single pass does slow the rate of temp increase. I don't know how you got the results you did unless it was plumbed wrong or had an air bubble trapped.
Testing has been done over and over.
Old Jan 16, 2014 | 09:59 AM
  #55
WSbalts's Avatar
No, I got your message loud and clear. Going on to call me a ******* for asking a reasonable question is a little excessive.
Old Jan 16, 2014 | 10:03 AM
  #56
no they don't ive ran both of the all they do is decrease recovery time and not so much that its worth spending the money on. its just like you saying swapping the cores for a dual pass is worthless
Old Jan 16, 2014 | 10:05 AM
  #57
good go get some books and read you will benefit from it
and its not excessive
Old Jan 16, 2014 | 10:13 AM
  #58
WSbalts's Avatar
Maybe not excessive, but unnecessary. I might be ignorant to the topic at hand, but it doesn't make me a *******.
Old Jan 16, 2014 | 11:04 AM
  #59
armcclure's Avatar
So ALL the other tests showing it decreases iat rise, including mine, are wrong?
Old Jan 16, 2014 | 11:09 AM
  #60
ThexGovenor's Avatar
Do the dual pass. Sorry MR B I dont agree. I think it does help a bit and the quicker recovery is worth it for such an inexpensive mod. Also Option B is great.
Old Jan 16, 2014 | 11:34 AM
  #61
Staged07SS's Avatar
Administrator
Administrator
The dual pass aids in recovery. Drops temps faster than stock setup.
It does not slow how fast the temps rise much though.
Old Jan 16, 2014 | 11:39 AM
  #62
only thing that changed for me was recovery time and it was not worth the money spent the only thing that helped was capacity
Old Jan 16, 2014 | 12:45 PM
  #63
armcclure's Avatar
How do you figure? On my single pass with a 2.5, my temps climbed like a stock setup on a stg2 pulley.
Yes it helps with recovery as well. But it also keeps them from climbing as fast. I thought this was general knowledge. Do you need logs for proof? I'm sure I can dig some up.
Old Jan 16, 2014 | 12:53 PM
  #64
Staged07SS's Avatar
Administrator
Administrator
I didnt say it doesnt help with rise.... I said it doesnt reduce the rise by "much".
Yes, it is slower, and all around better. I run a full GMR dual pass and Opt. B setup.
The main purpose of the dual pass is better recovery, so when you are driving around the track at full swing the temps can be controlled better.
My IAT2's still peak at 135-140 at the top of 3rd with or without the dual pass, that did not change. Nor did the speed of the climb change much. Recovery is what I noticed the most. Much, much quicker drop.
Old Jan 16, 2014 | 03:51 PM
  #65
Bluelightning's Avatar
Got Bewst?
Same here. I did a heat exchanger, dual pass and option b all at once. Once fully bled I personally saw no difference in peak IAT2. Climb rate didn't really change much either from what I noticed. Recoupe time was noticeably wayyy faster though.
Old Jan 16, 2014 | 04:21 PM
  #66
WSbalts's Avatar
As long as you're not doing pull after pull after pull after pull, you'd be golden then.
My lsj is my dd and I log a lot of highway miles so I'm looking at a fmhe just to help with recovery times. Dont want to run hot and stay hot
Old Jan 16, 2014 | 04:59 PM
  #67
armcclure's Avatar
Single pass ftw then.
Old Jan 16, 2014 | 06:37 PM
  #68
WSbalts's Avatar
I already have my fmhe waiting to go on, not gonna blow more money if I don't have to
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
