Japeatr's install pics of Powell Custom Fuel System
Old Nov 15, 2013 | 10:10 PM
  #151
JapEatr's Avatar
South Central *********
Ill gladly ditch the 1ks for the 1300s
Old Nov 15, 2013 | 10:13 PM
  #152
slitterell's Avatar
Maybe the administrator could split the thread? Lol
Old Nov 15, 2013 | 10:21 PM
  #153
mrbelvedere's Avatar
Originally Posted by slitterell
And he ran put of inj at 385ish on 80s before id1k
its not what I understood
Old Nov 15, 2013 | 10:22 PM
  #154
whole bunch of side busting going on and hi jacking of a thread about a guys install of a Bosch 044 surge tank fuel system not one of the nay sayers have ever tried on a Cobalt LSJ.
lots of opinions about the OP's car and what he should do, from folks who have not even seen the darn car run. Or someone flogging a drop in pump.
Thanks for the install pics thread Japetr.
SMH.
so from whining to side busting were making progress
Old Nov 15, 2013 | 10:31 PM
  #155
armcclure's Avatar
play nice kids.
jw you need to go to bed we got a busy day tomorrow
Old Nov 15, 2013 | 10:32 PM
  #156
JapEatr's Avatar
Lol ^^^
Old Nov 16, 2013 | 03:13 PM
  #157
BlkWdoSS's Avatar
SMH.
I have driven his car. Haha
I Am not claiming to have answers. I am merely asking questions and stating what I know about his car.
Sean and I know Vaughns car inside and out . I helped with tuning when the TVS was initially installed, discussed his engine build to the tiniest detail and have been working on helping him decipher the issues he has had since the car started to run again.
Sean and I have watched vaughn install return style, then install bigger fuel pump, then send that pump back to Deatschworks, then install bigger injectors, then rework his rewire system, then this then that then the other. We seen Area47 come down to tune and see if there was any issues he could help/address.
and after all of this Vaughn is still buying parts and trying new things because nothing has completely fixed the problem. I for one am tired of watching his car get all of these "ideas" thrown at it and not running right as ppl promise. So if I am in here asking questions its because I want his car to be what it was or to be something he can enjoy.
Old Nov 16, 2013 | 05:06 PM
  #158
slitterell's Avatar
Truth
Old Nov 16, 2013 | 05:12 PM
  #159
JapEatr's Avatar
Those that know me know how particular i am with my car. I enjoy working on it at my pace.
When things become a challenge or limitation i try to mitigate in the smartest way possible.
Yes pump capacity is a limitation, but im hoping the setup i just installed provides the necessary fueling for my needs.
Balance shafts are another area where i have tried to avoid doing something but will likely delete them soon.
I may go bigger injectors as well but i want to see what the fueling and nitrous present on the situation
Old Nov 16, 2013 | 05:26 PM
  #160
Josh@ottp's Avatar
Going to a bigger injector and dropping fuel pressure will give you more pump volume, so if you need to that would be a good route to go.
Old Nov 16, 2013 | 05:41 PM
  #161
Powell Race Parts's Avatar
How To Build The Proper Fuel System For Carbureted Motors - Chevy High Performance Magazine
I recall Area quoting Paul Yaw
http://www.injectordynamics.com/HPCalculator.html
Bosch 044 Fuel Pump Specs:
Bosch Part Number: 0580254044
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In-Line
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 1030 Grams (2.27 Pounds)
http://realstreetperformance.com/sto...on-test-5.html
this comparison clearly shows that at the ecotecs normal factory desired fuel pressure 044 is the best choice in this comparison. So far so good.
Fuel Pump Connections:
Inlet: M18 x 1.5
Outlet: M12 x 1.5
Electrical: Positive M6 / Negative M5
Old Nov 16, 2013 | 07:26 PM
  #162
ThexGovenor's Avatar
do you have NBS?
Old Nov 16, 2013 | 07:42 PM
  #163
slitterell's Avatar
Not yet. He is doing a delete soon
Old Nov 16, 2013 | 09:29 PM
  #164
JapEatr's Avatar
Fuel Pump Comparison Test : Real Street Performance Engine Parts, Pistons Rods Cams Valvetrain and More
Inlet: M18 x 1.5
Outlet: M12 x 1.5
The bosch 044 out flowed everything !!!!
Old Nov 27, 2013 | 03:22 PM
  #165
JapEatr's Avatar
should be wiring everything this weekend
Old Nov 27, 2013 | 04:20 PM
  #166
it may have but at what cost of running a reasonable base pressure if you need to jack the base to the moon then you defeat the purpose of a return system
get it done
Last edited by mrbelvedere; Nov 27, 2013 at 04:20 PM. Reason: Automerged Doublepost
Old Nov 27, 2013 | 05:16 PM
  #167
what on earth are you talking about? I am no expert but its easy. Pump is better, thats a fact the data is there; Japetr's system is good, thats a fact that race configurations show, (and you have no experience with this system) but then neither does anyone else here as far as I know. I assume Japetr will run about 58 lbs pressure to start. And will go from there. without limitations for that part of the system.
so thanks for the thread Japetr, sub'd for your next thread.
Old Nov 27, 2013 | 05:38 PM
  #168
what is 1 purpose of converting to a return fuel system that's referenced to be able to run a low base pressure so you can have better injector control with huge injectors so by having to run back to stock pressure(58psi) is not helping matters with large injectors
your(which I assume is a cloned system someone else designed) surge tank system is not some special over complicated out this world unicorn system your making it out to be
  #169
JapEatr's Avatar
Tune us currently set at 52
Old Nov 27, 2013 | 05:39 PM
  #170
if you can lower the base some the better
Old Nov 27, 2013 | 05:56 PM
  #171
Mr B its thanksgiving so I will join with everyone and give thanks for turkeys.
surge tank systems are far from new. Did I not say that its SOP earlier? That it is racing practice? Its just a tube with fittings in it. I am not sure why you are taking this tack since the get go, maybe its your thanksgiving mode?
Mine is totally not complicated. What is new, that no one has EVER done before, is mount it on a Cobalt , where it is located.BFD. Good job John!!
Happy thanksgiving Mr. B.
try to fly like an eagle.
Old Nov 27, 2013 | 08:20 PM
  #172
armcclure's Avatar
Only 1/2 right. The point of a pressure referenced system is to run a HIGHER pressure than normal to meet delivery needs, while allowing vac to pull the pressure down at low engine loads for better idle characteristics.
Old Nov 27, 2013 | 09:10 PM
  #173
advise's Avatar
At a 58 psi base he should only be running around 50 at idle vs stock 58 at idle
Old Nov 27, 2013 | 10:10 PM
  #174
I don't need to try to be an eagle and I am one soaring bad ass eagle
the second point is under hard acceleration where dose the fuel go and stay to the back of the tank if he dose not keep x amount of fuel in the tank then under a hard pull he can pump the sump and surge tank dry and with the amount of fuel he is going to be shoving into the engine it is more then possible that that can happen with or with out a surge tank what is needed is a rear pickup to prevent that
happy thanksgiving to you also Mr Powell
Old Nov 27, 2013 | 10:55 PM
  #175
I totally give up. Mr. B we gave you the math.you do it. i am tired of this bs. you will not starve a one litre tank with an operational lift pump and pressure pump even at 1000 hp. really.
go eat some turkey and get out the calculator. the flow and delivery tables have been posted.
then show us the math to prove your point.
right.
good nite
