Japeatr's install pics of Powell Custom Fuel System
Old Nov 27, 2013 | 11:22 PM
  #176
mrbelvedere's Avatar
so if that is the case you should never pump the stock sump dry and and then not need a surge tank
Old Nov 27, 2013 | 11:33 PM
  #177
armcclure's Avatar
John have you ever studied a stock canister?
Old Nov 28, 2013 | 12:56 AM
  #178
JapEatr's Avatar
South Central *********
Which John?
Old Nov 28, 2013 | 09:01 AM
  #179
lmao
Old Nov 28, 2013 | 09:22 AM
  #180
Josh@ottp's Avatar
The fuel pump flow data posted above doesn't list the walbro 400 and the walbro e85 pump. Also the numbers semm very high compared to everything else I have seen.
Fuel Pump Comparison - Bosch 044 vs. Walbro 416lph vs. Walbro 255lph vs. Supra Denso
Old Nov 28, 2013 | 09:54 AM
  #181
slitterell's Avatar
What numbers?
Old Nov 30, 2013 | 03:49 PM
  #182
zrated89's Avatar
josh, i am running the same Walbro 450 E85 pump that you sell. Not to burst your bubble, but i ran out of fuel at only 26psi on my 6262 turbo setup and E85. So im back to the drawing board as well
(and the assembly DEFINATELY had to be modified to fit the pump lol the thing is ******* huge)
Old Jan 30, 2014 | 02:36 PM
  #183
JapEatr's Avatar
quick update on this. the 044 is working well. as soon as car is driveable again ill post comparison logs
Old May 26, 2015 | 03:05 PM
  #184
JapEatr's Avatar
im likely going to have to relocate my FuelLab regulator back to the fuel rail to make room for my turbo charge piping
Old May 26, 2015 | 06:04 PM
  #185
JapEatr's Avatar
Also will be going to 1200 or 1600FIC injectors
ineedacobaltss
Nov 7, 2015 02:25 PM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
DocSvensk
Sep 27, 2015 02:24 PM
