Just installed zzp s3 HE
So I was wondering if any of you that have a heat exchanger noticed a drop in coolant temp after the install. Also would it have taken more coolant? all help appreciated t
Thanks
Thanks
in the heat exchanger. lol. then there is that filler neck that is bolted to the supercharger. thats where u fill it. and then on top of the stock heat exchanger there is a bleeder valve for proper bleeding of air.
Why would u run more than a 50/50 mix. It don't cool better. If anything it don't cool as good if it's strait.
Straight dexcool in the IC system? You should always run at least 50/50 mix. Dexcool by itself is simply a lubricant/anti-corrosive/colligative and does not transfer heat well. The water that is mixed with the dexcool is what actually performs the transfer of heat. In hotter climates where the tempurature doesn't get to freezing it is more beneficial to run a higher water mix in the IC; i.e. 75% distilled water/25% dexcool. You should always run a 50/50 mix in the engine coolant.
You installed a heat exchanger and didnt know it was a seperate system from the engine coolant? So have you been running around with a bone dry intercooler? Did you get instructions with it and plumb it into the right lines? I just want to make sure you got everything correct, dont take this the wrong way. Oh and I go 50/50 mix.
has anyone made a DIY for installing a H/E????? I haven't seen one.
It keeps temps around normal levels which are about 180 degrees on an SS/SC. You wont hear it kick in until around 195 degrees and the temps will drop drastically then. If you have no mods that cause extra heat then you wont really see any difference.
Agreed !!
The famous CobaltSS.net excuse ....
I installed my H/E tonight after having for almost 2 yrs and on the drive home from the shop I watched both IAT1 and 2 saw a 20 degrees difference a lot better then the 30 to 40 I saw before
