Le Riceburners OFFICIAL Build Thread
Old Mar 18, 2014 | 09:01 PM
  #676
Okayy... just making sure i didnt totally **** myself lol.
Old Mar 18, 2014 | 09:02 PM
  #677
TStone's Avatar
Oh no. Not on this part atleast. hehe
Old Mar 18, 2014 | 09:05 PM
  #678
Bluelightning's Avatar
Got Bewst?
As TStone said, you'll be fine. Different if you went all out on a motor. Look at Infra's motor before he swapped to his 2.1. It's seen 7500+ rpm for years. Bone stock bottom end. Now continuing on in his greyline winter beater that's the same set up as yours.
Old Mar 18, 2014 | 11:17 PM
  #679
His bottom end was never apart though and he hasnt messed with the balance shafts i think. But everything checked out ok putting my bottom end back on. The thing is you cant check clearances without destroying a new set of bolts
Old Mar 18, 2014 | 11:35 PM
  #680
BlackielawlessSS's Avatar
Can some one answer my thought. I am seriously trying to learn...
Old Mar 18, 2014 | 11:49 PM
  #681
How agressive of a tune are you thinking? Adding boost will cause stress on the block, but correct me if I am wrong, as I have always built NA V8s. I ran the biggest cam I could run in a stock block for well over 5 years and beat the **** out of it. I never had one issue. I don't see how with a good tune, cams could put stress on the block. I dunno I probably need to step out of the V8 box. Sorry just thinking out loud.
I think you misunderstood the direction of question. I am not worried about my bottom end because of the cams, but the balance shaft delete, which was driven off of the crank chain and they were in the block.
Boost does indeed crack pistons lol.
Im not wanting a very aggressive tune, i want to daily drive my car and as long as possible. Yeah i know, we all want the best of both worlds, haha. Luckily the e85 helps to have a safe yet aggressive tune
Old Mar 19, 2014 | 12:10 AM
  #682
SPDDMN36's Avatar
I just want 500 reliable hp. Is that so much to ask for?
Old Mar 19, 2014 | 07:55 AM
  #683
TStone's Avatar
That was on a built bottom end Adam
Old Mar 19, 2014 | 08:06 AM
  #684
armcclure's Avatar
Which thought
Old Mar 19, 2014 | 08:10 AM
  #685
574's Avatar
574
Your talking about plasti gauging then you just used the old griddle bolts
Old Mar 19, 2014 | 08:16 AM
  #686
those are stretch bolts though i think. but anyway too late now we didn't do it lol
Old Mar 19, 2014 | 08:23 AM
  #687
574's Avatar
574
Bed plate bolts are tty but you can re use them. Especially if your just checking clearance
Old Mar 19, 2014 | 09:07 AM
  #688
So are they going to be neutrally balanced now? I really want to do my own build versus letting someone else do it, I have just never worked on a sideways engines. Sorry if I ask a lot of stupid questions, I really just want to learn.
Old Mar 19, 2014 | 09:14 AM
  #689
armcclure's Avatar
i understand what you were asking now.
4 cyl inline engines have different vibrations than v engines. usually balance shafts (which are actually anti-balance) are used. There are 2 offset shafts that rotate opposite of each other, creating a separate wave that "covers up" the engine vibrations. However in a performance motor these can actually become harmful, not to mention they rob hp that increases exponentially with rpm.
Old Mar 19, 2014 | 09:18 AM
  #690
Ok I understand now, this is why you delete it.
Old Mar 19, 2014 | 09:26 AM
  #691
i'm hoping the ati cancels out any 'loss of harmonics' and vibrations caused by deleting them
dude you have stuck through this entire thread and seen how many rediculous questions i've asked. its ok these OG's are here to help and as i learn more i can start to help as well
Last edited by riceburner; Mar 19, 2014 at 09:26 AM. Reason: Automerged Doublepost
Old Mar 19, 2014 | 09:33 AM
  #692
Awesome! I really have been trying to learn about them, and how they work.
Old Mar 19, 2014 | 09:37 AM
  #693
TStone's Avatar
It's all magic
Old Mar 19, 2014 | 09:51 AM
  #694
armcclure's Avatar
There's a big difference between vibrations and harmonics.
The only thing the balance shafts do is cancel out large wave feelable vibrations.
It's separate from engine harmonics.
Old Mar 19, 2014 | 09:56 AM
  #695
TStone's Avatar
Don't wanna upset the db
Old Mar 19, 2014 | 10:23 AM
  #696
Staged07SS's Avatar
Administrator
Administrator
I'm glad
Most want to be spoon fed info.
Old Mar 19, 2014 | 10:24 AM
  #697
armcclure's Avatar
#goat
Old Mar 19, 2014 | 10:26 AM
  #698
I'm glad
I am a hands on guy, but seeing as no one around here is doing a build, I have no choice but to read, ask questions, and then go from there. My biggest challenge I have faced was running stud mounted roller rockers on a sbf. Typical ford rockers are tq down to spec. Well not the stud mounts. It was my first build. I bet I tore the top end off 6 times, before I finally got them adjusted.
Old Mar 19, 2014 | 10:31 AM
  #699
you seem to know enough about how traditional v8 engines work man, as my v8 pals have found out, 4cyls are quite different, but essentially work the same way, just kinda switched around. its been a learning experience for them and will be for you too.
none of what i learned during this struck as too odd though, since i had nothing to compare it to
Old Mar 19, 2014 | 10:40 AM
  #700
I have built several V8 engines, so I know the legistics of how they work. I just look at the ecotec and say oh god, what have I done They seem simpler as far as intake, and head removal, vs a V8. I guess I need to get the gm build book, and stick my nose in it.
